Question about 1981 - 1986 Kenworth C500 Engine Coolant Thermostat Seal 25020
The odometer on my kenworth t2000 not working
1998 t2000 kenworth truck has no running lights or dash lights how to fix them
Fuse ?? this happens sometimes when the trailer has short some place in it , later models use a separation relay to power trailer lghts so that a short would only take out trailer lghts but in 98 they didn't a good shop mech could retrofit one in so that cant happen
Jul 28, 2016 | Cars & Trucks
Where is the motor Heater resistor on a Kenworth t2000 2004
the resistor is normally found by the heater motor in the same cover box, follow wires from motor to resistor should be close.
Jan 22, 2016 | Cars & Trucks
I need a wiring diagram for 2004 Kenworth T2000 with a Cummins ICX engine.
KENWORTH WIRE DIAGRAM FULL - YouTube
? 5:38
www.youtube.com/watch?v=IwFAUHcCTN4
Aug 31, 2014 - Uploaded by Mack Diesel
KENWORTH WIRE DIAGRAM FULL REPORTS THE EMAIL softdieseltruck@hotmail.com softdieseltruck ...
Sep 10, 2015 | Retail Supplies
Kenworth t2000 1998
Should be under the dash drivers side.
Aug 31, 2014 | Cars & Trucks
I have a 2001 kenworth t800. the brake lights are
there is either a 50 amp mega fuse at the alt. or a 10 amp fuse at the engine side of firewall driver side of truck. more than likely that is your problem.
Apr 14, 2010 | Jada Option D Kenworth T2000 Truck Trailer
Need to remove ac clutch on t 2000 kenworth
There are a few different styles for the T2000
One common one you remove the nut in the center and install a 1/2" bolt and tighten it down, this will pop the clutch off the shaft, then just remove the magnet.
the others require a puller
Sep 23, 2009 | Denso Nippondenso RS232
KENWORTH T2000, WIPERS not spraying windshield wiper fluid
one of two problems i make sure the pump is working or the ends on the sprayers are pluged up if so take off and run a small pin in the hole to clean them
Jan 27, 2009 | Jada Option D Kenworth T2000 Truck Trailer
1981 - 1986 Kenworth C500 Engine Coolant Thermostat Seal 25020 Logo
41 people viewed this question
Top Stant Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Stant Vehicle Part and Accessory Expert? Answer questions, earn points and help others
