I already open my tl 902 scotch laminator but cant remove the jam
Small id picture got jam inside i had open it already but cant get the plastic that stick to much
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: How do I remove jammed
Use a box cutter and reverse the feed
Posted on Aug 29, 2008
  • 53 Answers
SOURCE: i have a scotch brand laminator tl901- it is
First, make sure that the unit is unplugged and has sufficient time to cool off. Then remove six screws on the bottom of the laminator. The screw driver shaft must be thin enough to fit into the holes where the screws are located. Two are very easy to find -- one on each side in deep holes. The other four are hidden under small black rubber disks that the laminator rests on. peel up the rubber disks and remove the rest of the screws. At this point it is easy to remove the cover and remove the jam. To replace the cover you must use a thin tool to pull back the release level so it will fit into its opening in the cover. Replace the six screws and you should be able to ready to laminate again.
Posted on Oct 06, 2010
  • 17 Answers
SOURCE: Hi, Our Ibico IL19VT Laminator (A2)
You can open this yourself but i recommend sending it for repair. If you decide to do it yourself here is how: turn the unit over and on the end with only one screw (not the power setting side) take it out using a Philips screwdriver. Next you will need size 3 and 4 hex bits. Use size 4 to undo the 4 hex screws. Hold the non power end and it should slide off. You will see four rollers two on each side of the heater element. Using the size 3 hex bit undo the 4 hex screws at the exposed end and lift up and out the 2 housing bits. Careful as these are made of plastic and break easy. Remove the offending material and then put everything back together.
Simples!
Posted on Jan 14, 2011
SOURCE: The last time I used
There are two screws on the bottom which are visible. Leave them alone. The four screws that hold the bottom on are UNDER the rubber feet. Gently lift one edge of the rubber feet and then carefully peel them off. You will need a long thin Phillips screw driver to remove the four screws, UNPLUG the unit before opening it.
In most cases the plastic will be wrapped around the orange/red colored roller. This roller cannot be turned unless you push the "Release" lever. Using a tweezers, try to grasp a corner of the end of the rolled up plastic. Pull firmly and steadily on the corner until you have enough free to grasp with a needle nose pliers or a forceps, Then work your way across the entire end of the plastic sheet until its free. Finally, reposition the pliers or forceps toward the middle of the freed end and firmly pull to unroll completely.
Remember, you must be pushing on the "Release" while doing this or the roller will not turn. When you start, you may have to move the roller to get it to a position where you can try to grab an end corner of the plastic sheet. You should be able to do this if you a pushing on the Release lever.
Finally, if you have left the rolled up plastic sheets on the roller so long the are fused into one mass, my directions my not work. In that case, try slitting the entire length of the rolled up plastic with something like an xacto knife, BUT DON'T **** THE RUBBER ROLLER. That's tricky, but at this point you have nothing to lose.
Took me 20 minutes to figure out how to open the unit. Ten minutes to take out the wrapped up plastic sheets
Posted on Mar 14, 2011
I jammed the laminating machine, so I unscrewed and opened the machine...but now I don't know how to roll out the paper? Please help me find a way to take this out without breaking the machine!
Carefully try to turn the roller one direction and then the next. If they move, you will see the feed direction the paper loaded from. Carefully move the rollers in the opposite direction letting the paper unwind. Do not force the gears. Hopefully the paper is not fused to the rollers.
Mar 03, 2015 | Scotch 9" Tl901 Hot Laminating Machine /...
My document has jammed inside the laminator. How do I remove the jammed document?
it is not possible to give advice or answers when you simply make unrelated statements...
Oct 27, 2014 | Gbc Creative 9 Laminator
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Please help!!! I put a pouch into my scotch TL901 laminater the wrong way and it is completely Jammed in the middle of the machine!!! I used a flashlight to see how bad it was ad it is completely shredded...
Unplug laminator. If it does not open up -check to see if the machine has a pouch jam lever. The lever will make it easier to remove the jammed pouch. Put the screw back after you clear the jam.
Jul 12, 2017 | Office Equipment & Supplies
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Jun 26, 2012 | Gbc HeatSeal H425 Laminator
SCOTCH TL901 MANUAL
I have a scotch tl901. The laminating sleeve went into the machine and must have rolled around the roller inside. Is there a way to get it out? Is there a way to open the machine? I must have put the sleeve in open side first.
Oct 03, 2010 | Office Equipment & Supplies
I have a scotch brand laminator tl901- it is jammed...and making a clicking noise...is there a way to open the system and try to unjam it?
Jul 10, 2010 | Office Equipment & Supplies
Hi, Our Ibico IL19VT Laminator (A2) has paper jammed inside of it. There are no reverse mechanisms on the laminator. The only feasible method is to open the laminator up at this point, whether or not...
Simples!
Aug 21, 2008 | Office Equipment & Supplies
k24674
