Question about Sony TA-E9000ES Amplifier
TA-N9000ES Amp - Standby light constantly blinks - no sound
Don't know if this is a problem with my amp or my TA-E9000ES processor but the standby light on my TA-N9000ES amp blinks continuously and I have no output from the Amp. Have had many problems with the processor and suspect that is the problem but the owners manual and service manuals for the amp give no clue as to what a blinking standby indicator light is indicating. Does anyone know?
  • j-rad Dec 29, 2007
    Same exact problem here... Tried unplugging all but power supply, but it didn't fix the problem, just isolated it to the amp itself. Very disappointing to have spent this much money and have something solid state fail. The remote to the master unit also eats batteries in about a week.
  • Anonymous May 24, 2009
    this thing is a piece of junk. do not buy one. i have had the amp and pre both in the shop. they were fixed, but new problems arose. i have given up.
    Problem Solver:
  • 20 Answers
The flashing light is indicating that a fault has been detected, and it is staying in "protect mode". First disconnect all cables from the processor (except the power cord) and then power up the processor. This will eliminate the possibility of a shorted cable or a problem with any connected components. f the light still flashes, there is an internal problem and the processor will require profesional service.
Posted on Oct 10, 2007
  • 4 Answers
EXACTLY AS SAID BY BRUTEAUDIO.
Posted on Oct 11, 2007
SOURCE:
TV powers off after an hour aprox.
Hi the auto standby function MIGHT have been activated to disable PRESS MENU BUTTON ON REMOTE SCROLL DOWN TO SETUP & PRESS OK. SCROLL DOWN TO OTHER SETTINGS & PRESS OK ....SCROLL down to AUTO STANDBY AND PRESS THE LEFT & RIGHT ARROWS To SET THE OPTION TO OFF ....GOOD LUCK
Jul 02, 2016 | Panasonic Televison & Video
Standby led blinking, no sound
Acording to the manual you have it in an invalid mode.
Jun 04, 2014 | Sony TA-N9000ES 5-Channel Amplifier
Sony Grand WegaKDF-E50A10 standby light constant flashing green
Sounds like the main system control-chroma IC fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 09, 2014 | Sony KDF-E50A10 50 in. LCD HDTV
Hello! I have a problem with my Sony S-master 5.1ch Full Digital Amplifier (DAV-S880). When I start it as blinking standby light and nothing works. I have checked the fuse.
If the light blinks you need not check the fuse, its an indication that your amp has gone into protection mode due to an output failure. You will have to take it to an authorized service center because the S-master chip is a surface mounted device which needs a specialized equipment for de soldering and soldering.Even an ordinary service technician might refuse to handle this work.
Aug 11, 2011 | Sony TA-N9000ES 5-Channel Amplifier
I have a Sony power amp TA-N9000es there is no sound do you need a remote or is there a volume control inside the case. Have tried every input every speaker connect there is just no sound. what can i do...
It's just a big amp with no controls you would change during normal operation. There's no remote. You don't name any source or if you even HAVE one attached. THAT would be a good place to look for missing sound.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/sony/sony_ta_tan9000es.html
http://dl.owneriq.net/f/fede44fb-b9ba-4e03-87bb-d0f3e29e22ef.pdf
Set the BTL/Normal switch on the back to Normal. In fact, any switch or knob with BTL, set it to whatever choice is NOT BTL.
Mar 24, 2011 | Sony TA-N9000ES 5-Channel Amplifier
Sony TA-E9000es. No Display, No Sound. Software Ver 1.18. Has Bulletin HIFI1-99-028R1 performed. (Add capacitor, replace resistor)
also replace Q108 @ Q109 on power board. If that does not fix it then also replace PH101 & PH102. Also on Power board.
Jan 14, 2010 | Sony TA-E9000ES Amplifier
I have 2 questions will my SONY TA-E9000ES preamp work with my SONY STR-DG720 7.1 RECIVER and what SONY ES Amplifer was spefically made to work with the TA-E9000ES WHEN IT WAS ORIGANLY PRODUCED
Here's a page for the 1st one
http://home.online.no/~espen-b/ta-e9000es/
It will work with your 7.1 receiver. Just use one of the inputs on the 7.1 to connect to the Pre-amp
PLease rate my help if this helps
Thanks
Nov 04, 2009 | Sony TA-E9000ES Amplifier
Sony TA-AV421 Amp
im needing help connecting my audissey aps 5+2 energy floor speakers . im confused on the 2 channels
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony TA-N9000ES Flash light when turn on.
an amp of this size generates alot of heat internally when in use as these use mosfet ICs and can get very hot.
your problem is most definately dry solder joints and possibly quite a few at that.
i've repaired quite a few sony surround receivers with similar problems and have all been down to dry solder joints.
hope this helps.
Jul 26, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony TA-E9000ES Amplifier Logo
1,517 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
