Question about Xantrex Technology Computers & Internet
How to open duracell 500 to change bulb - Xantrex Technology Computers & Internet
How do i open the flash light to change the batteries in a duracell 500
This query is not really relevant to Cameras, now is it, dear ? Have you looked in the manual ?
Oct 01, 2017 | Duracell Cameras
Duracell 1000 flashes once. Nothing more. Doesn't work in any of the three modes.
*NOTE: We can only provide support for our products. Some Duracell Flashlights and Portable Lighting Products are distributed by other Duracell licensees. If you have questions or concerns regarding these products, please contact them for support.
Please do NOT contact us for support of these flashlights from the DURACELL® Durabeam™ Ultra Series:
  • 250 lumen flashlight
  • 300 lumen flashlight
  • 500 lumen flashlight
  • 1000 lumen flashlight
Instead, for support of flashlights from the DURACELL® Durabeam™ Ultra Series, please contact:
TechnoMate - phone: 1-888-910-2280 (8:00am - 5:00 Pacific Time)
The reviews here are NOT GOOD!
The reviews
Amazon com Customer Reviews Duracell Durabeam Ultra High Intensity 1000...
Jan 05, 2016 | Duracell Camping, Backpacking & Hiking
Do I need to worry about how often salons change the bulbs in their tanning beds?
Yes - even though in theory tanning bulbs can last up to 1,000 hours, if they are not changed very regularly, they can seriously affect the quality of your tan. Bulbs should be replaced after 500 - 600 hours use.
Feb 18, 2013 | Health & Beauty
I have a duracell 800 watt invertor which i hooked up backwards to the 12 volt battery. sparks flew and it will not work? help
Any particular reason for hooking it up backwards? most likely something inside is fried and you will prob have to purchase a new unit.
Good luck
May 04, 2011 | Duracell 1500W Power Inverter (D1500)...
Can't open the flash light to change the batteries? Does the bottom open up? Do the batteries get replaced from the top by removing the bulb first?
The back, tail cap, should be unscrewed from the maglite to replace the batteries. It can be pretty hard to open as they are generally not opened very often and there's a rubber seal to keep it water-proof. You could try using a pliers or vice but be careful not to squeeze it out of shape.
There's also a possibility that if the batteries are in it a long time that they have leaked and the leaked chemicals have sealed it. If this is the case you may be able to get the maglite replaced depending on what brand of batteries were in it. Maglite have an agreement with the makers of Duracell, Ever-Ready and Ray-O-Vac to replace the Maglite if one of their batteries leak in it.
Details are on the bottom of page at http://www.maglite.com/faq_details.asp?faqProd=C
Nov 01, 2010 | MagLite 4 Cell C Flashlight Black
1500 watt duracell inverter and two 4' floro fixtures. It will not start both at same time. But will start one at a time. need some sort of time delay.
The current drawn by the two starters kicking in must be activating the foldback protection
Break the supply line and fit an isolating switch to one of the units.
Nov 05, 2009 | Duracell 1500W Power Inverter (D1500)...
2007 ford 500 rear turn signal bulb replacement
This is straight from the owner's manual.
#1 Make sure the headlamp switch is in the OFF position and open the trunk.
#2 Carefully pull the carpet away to expose the backside of the tail lamp assembly.
#3 Remove the nut and washer assemblies, then pull the lamp assembly away from the vehicle.
#4 Remove the bulb socket by rotating it counterclockwise, then pulling it out of the lamp assembly.
#5 Pull the bulb straight from the socket.
Install new bulb(s) in reverse order.
Good luck
Apr 01, 2009 | 2007 Ford Five Hundred Limited Sedan
Computers & Internet Logo
96 people viewed this question
Top Xantrex Technology Computers & Internet Experts
steve morris
steve morris
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
