Materi asas-asas kearsipan - Computers & Internet
How to export log from CISCOASA?like other cisco device logging 1.1.1.1 i want similar kind command in CISCO ASA
ASA's log is usualy stored localy on ASA itself, so easiest way to export that log is to go with telnet/ssh/console on it, do a command : show logging and copy/paste output into a new file.
but beware - this log is really short and as soon as ASA is rebooted - it's gone.
you could set asa to log to a syslog server (free on linux/freebsd or for windows use KIWI app).
that way all ASA log output is stored on pc/server running your syslog server.
Jan 03, 2011 | Cisco ASA 5510 Firewall
My cisco asa 5505 lost it image file ... how can i get the image back
if it is really deleted from FLASH, you will need to connect to ASA with a console cable, start up TFTP server on your pc, and in TFTP copy your ASA image file (.bin - on your CD that you got with ASA) so that you can get it from pc to asa.
then use tftpdnld command to set all the parameters on asa and start the download of the file from your pc .... after it has been done - just reboot asa :)
Dec 15, 2010 | Cisco ASA 5500 Firewall
Replacing a PIX 515E with an ASA 5510
Best way to migrate is to take the configuration of the old PIX and TFTP it to a PC or other server for safe keeping.
Then boot up the ASA in a lab environment and TFTP the configuration to the new unit and reboot. There will be some commands that don't translate correctly, but you can compare the configurations to each other to make sure all the access lists and NAT statements get transferred across.
Keep in mind that the PIX and the ASA name their interfaces differently, so there may be errors when you transfer the configuration. You can edit the configuration offline with something like Notepad and change the names of the interfaces to have it work.
Jan 29, 2010 | Cisco ASA 5510 Firewall
Cisco ASA 5505 Firmware
Yes, it is possible and Yes you have to purchase it from Cisco.
Sorry, that is how they make the big bucks.
Consider a service contract on the unit, then you can download the firmware much cheaper.
Jul 10, 2009 | Cisco ASA 5500 Firewall
Hello all can you please help me on how to restore the configuration of my ASA 5520? thanx
If you are going for factory reset use the following commands
asa>enable
asa#write erase
asa#reload
Dont save the configuration when it prompts for it.
if you want to restore the configuration from the backup
1. You need to have a TFTP server
2. Locate the config file on your TFTP server
3. TFTP server should be reachable from ASA
then
asa#copy tftp flash
give the tftp server ip address
give the configuration file name (as exactly on the TFTP server)
reload
Apr 01, 2009 | Cisco ASA 5520 Firewall
Problem in installing the asdm image ASA 5520 ver 7.1
I had this same issue on my ASA 5520.
1. Copy the config and IOS image to a tftp server.
2. Format flash (disk0)
3. set rommon server, ip addy, and file settings.
4. tftpdnld
5. Once the system has booted to the image copy the asa image file, asdm image file, and config to flash
6. configure asdm image default location and reload
Feb 27, 2008 | Cisco ASA 5520 Firewall
Contax 137ma ASA will not move...
I have a very vague memory (I used to sell cameras many years ago) that there is a stop at ASA 400 to prevent you accidentally selecting a faster speed. I do remember something of the sort on a camera of that era but it may not have been the Contax. IIRC, you have to lift the dial a *second* time (i.e. a bit higher) to get it past the stop. Hope this helps but it may be a red herring!
May 15, 2007 | Contax 167 MT 35mm SLR Camera
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
