Bell b30d engine fault code not in service manual which is for turbo protection over ride. Checks on turbo show no defects/faults.
  • 163 Answers
SOURCE: sharp sf2116 (lanier6716) photocopier
press c interrupt 0 interrupt ,20 copy key,1 copy key
Posted on Sep 23, 2007
  • 7 Answers
SOURCE: general protection fault
based on limited description of the issue possible causes - 1. memory corruption 2. corruption of bios 3. boot sector on hard disk failed or crashed
Posted on Oct 04, 2007
  • 208 Answers
SOURCE: Tektronix Phaser 850 Service Fault 13.019.40
Most likely a bad print heat. One of the ink heaters is overheating.
Posted on Dec 07, 2007
SOURCE: xerox 5334 fault code U4-1
Reset the fault code first as follow:
Enter in diagnostic mode
Enter 20-3 and press 0 then press start again .
Hope it will solve if not done check the heater lamp continuty if found fault replace same.
Posted on Sep 20, 2008
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
Posted on Sep 25, 2008
Why does my Teac ag h500 keep saying protect?
Hi. Unfortunately the protection circuit is saving your speakers from a fault, most likely one side of the amplifier in the unit is defective.
This needs an engineer.
Service manual is here if you need it. TEAC AG H500 Manual AM FM Stereo Receiver HiFi Engine
Oct 02, 2016 | Teac Audio Players & Recorders
Fault code 1 Fail 31 Spn1569 2015 Cascadia Cummins engine
spn 1569 relates engine protection torque derate -condition exists.
critical fault codes related to engine operation are active
code 1 means urgent attention
A sort of limp mode setting that requires immediate attention by a cummins service center to prevent further damage to the engine
go google and type in--- cummins engines fault codes (or cummins engine fault code 1569) and there are pages of pdf downloads that list all the codes and what they stand for
Oct 07, 2015 | Cars & Trucks
Obd2 code p1237 on honda civic diesel after engine malfunction light went off car goes into limp mode especially when engine is cold what does obd2 code p1237 mean what is the fault car runs ok then
DTC ) fault code ) - P1237:
Boost Control Positive Deviation
This fault code can be set when the fuel tank is empty or the specified fuel is not used. ( supermarket fuels etc have been known to cause this.. )
It can also be attributed to a turbo fault - if the fault is no turbo boost.
Jan 20, 2015 | Honda Cars & Trucks
98 Buick Park Avenue (Turbo) P0717 fault code,
CODE PO717 IS - A/T INPUT SHAFT SPEED SENSOR LOW INPUT CONDITIONS.YOUR INPUT SHAFT SPEED SENSOR COULD BE DEFECTIVE.CHANGE FLUID + FILTER IF IT HAVE NOT BEEN CHANGED IN A LONG PERIOD OF TIME.
May 29, 2010 | 1998 Buick Park Avenue
Fault code 45- how do i repair it?
hi i had that fault i found it was a small box the size of a fifty pence on the osf with a small air pipe coming from the bottom of it try a run the car then take the pipe of if its working you will see the change in the engine
May 09, 2009 | 1995 Subaru Legacy
Washer delivered today - got half way through first load, stopped with error code e16 on display. Can't get a service engineer until next tuesday! Any ideas how to get it going again before then?
E16 is listed in the service manual as a heating element fault.
Water Heating Element is short circuited or defective electrical insulation.
Unplug the appliance and take the rear cover off.
Check the wiring to the element and if you have a multimeter do basic checks on the element.
You may have to replace the element to try and cure the fault.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Washing Machines
Suzuki grand vitara fault code
I guess you have an HDI engine (possibly RHZ) as this fault is very common on that model. Quite possibly it will just disappear. It is not likely to be the turbo. Swap the electrovalve (pneumatic solenoid) which controls the turbo with one of the others (there are three beside each other on the inside of the wing, and see what happens. If the fault moves elsewhere that confirms electrovalve fault - so replace valve it.
If not check the vacuum hoses and test things such as the EGR for vacuum leaks. Another possibility is a faulty (or even just dirty) MAF. This is very easy to remove- it is on air intake - so remove and clean with wWD40 or similar.
Nov 08, 2008 | 2002 Suzuki Vitara
143 people viewed this question
k24674
