So how do wire this set set up to a bridged amp any help would be appreciated
assuming that is a dvc dual 4 ohm speaker, and you have a 2 ohm bridged amp, you run a positive from each side of the speaker into the bridged positive of the power amp, and run a negative from each side of the speaker into the negative bridged terminal of the amp. if, indeed, you have 2 4 ohm voice coils, running them bridged in parallel wiring will bring the load to 2 ohms. if you have 4 voice coils, of 4 ohms apiece, you could run all 4 parallel into the amp, but that would bring the load down to 1 ohm, and you would have to make sure you8r amp can support 1 ohm operation.
