Question about Toshiba 57H81 57" Rear Projection Television
Colors are out of tune
Changing from ant, video1, video2 , video3 and so on the colors are different in every option would like to know how I can adjust the colors to each one or do you have the correct settings for the tv so that the colors are corrected on the tv.Would like to have the original setting for this tv. Thank You
    President:
  • 4,402 Answers
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 19, 2007
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
Pip now is on the souce menu whereas cable, video1, and video2 were there before. How do i get rid of pip and return to the former sources?
close the pip window first
if your tv/video button on your remote brings up
an input selection menu either press the number
of the ones you want or use the chan^chanv buttons
to select
Nov 29, 2007 | Zenith A27B33W 27" TV
Tv wont stop scanning between tv, video1, video2,video3
Possible there is a sync issue as the return pulses do not come back to lock the scanned channels. This can be an issue which can vary from a simple loose connection to a fault iin the signal processor. This would need the help of a serious probe with a signal tracking using a scope and assisted equipments. Take consensus as this can be tricky before you tamper the board.
Oct 30, 2011 | Toshiba 36A43 36" TV
Hi i have play station 2 and i don't know what to put the tv on to play my games
Well first if you don't have a factory remote you will have to purchase a universal remote that supports i'll products program using factory codes or do a manual search( which takes a little time but I have had better luck with for more functions ) after programming you press tv/vcr button in which it should display ant. vIDEO1 video 2 and component repress button until desired chann el is highlighted coincideing with whatever location you have your device connected rear is video 1 and multicolor is component and front is video2
May 18, 2011 | iLO IWT3206 TV
We understand that your problem is: I have a Panasonic PT-53WX42 53 and I am trying to connect with the component connection but it will not cycle through component connection Just cable, video1,...
This problems,most of the times component cable are old and time passing and wheather conditions is ur ememy.Replaced the RCA component cable and do a hard reset the tv by unplug,replug it back like about and hour later.Go into ur tv menu and tries every setting to resetting back to the factory setting,this problems.Should be solved.
Dec 19, 2010 | Panasonic PT-53WX42 53" Rear Projection...
TRying to get my PC to TV converter up and running
I just purchased the Kworld 1600 PC to TV Game Box today. I also had the same problem as many others seem to have had. The TV screen displayed only colored bars. After searching on line for troubleshooting ideas I finally was able to correct the problem, thanks to help of people responding to these problems on "FixYa", and I thank you, as I was ready to return the product at a loss of 15% of the cost (restocking fee).
I am using a Toshiba Satelite L350D with Vista Home Premium and a 2005-32"JVC TV.
First ensure that the Monitor Y-cable supplied has been properly installed to your PC and your TV (my first mistake). Each plug is individually identified, that being, TV, monitor, scan cnvtr.
Second, on Vista go to Control Panel, open (Double left click) the personalization icon. You can then open your display settings.click on advanced settings, this will open a window for your graphics card. Click on "List All Modes", use an 800 x 600 High Color Mode, 16 bit, 59 or 60 hertz, hit 'OK' and that window will close.Then hit 'Apply' in the Graphics Card window(the screen will go black and then set itself to the new mode). You may have to try a few different 800 x 600 modes to find the best one for your TV.
Thirdly this converter is only for video, not audio.
For audio you must use a 1/8 stereo plug from your PC headphone jack to an RCA adapter into the Left and Right Audio Input of your TV.
Make sure you are using the same Video Input Section for both your audio and video (Video1, Video2, Video3, you cannot plug the video into Video1 and the audio into Video2).
After setting this converter up on my Laptop I was also able to plug it into my 7+ year old desktop (Cicero P4, XP Home Edition).
I hope grouping these 3 problems into 1 will help others and save them some time and frustration.
Thanks again to everyone on "FixYa" for their help.
Mar 14, 2009 | KWorld PC to TV (0872880887527) Video...
Car dvd
I called Sony and they zipped me right through it, without asking for a credit card! They have fantastic customer service! Just for that reason, I will continue to purchase Sony products!
Power up your player by pushing the power button on the screen. Press input, then press the down button on the left, selecting NTSC for all inputs (Video1, Video2, Video3, and Video4). Your screen will immediately flip back to color and be as good as new!
The fix was so easy! Hope it works for you too.
Apr 27, 2008 | Sony MV-7101 Car DVD Player
Connevting to an LCD TV
This will vary by TV model, but some televisions route external signals to a separate video setting, often only reachable through the remote. Try looking for a "video" or "input" or "mode" setting on your remote. On my TV it's a "video" button that toggles from channels to Video1, Video2, Video3 and Svideo, then back to channels.
If that doesn't help you, let me know the exact make and model of your TV and I might be able to find something more specific.
-Dyllan
Jan 07, 2008 | Sony PlayStation (PS) Console
Toshiba 57H81 57" Rear Projection Television Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
