Whirlpool washing machine awm 5100 has a red light like a horizontal s and will not operate
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
yalmer
  • 549 Answers
SOURCE: whirlpool awm 049 washing machine
If the washer leaks only during the fill cycle, check the following:
Air-gap device: The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube:There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout:Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During spin cycle only:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Look at the entire hose and correct any problem you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it.
Pump: If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Main tub seal: The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Outer tub:The steel or plastic outer tubs can rust, split, develope a hole in some way. If this happens, you may have to replace the outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Feb 07, 2008
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
SOURCE: My Whirlpool AWM 8143 washing
The drainage pipe was blocked so I simply un-clogged it and made the machine drain and it all seems to be going well. Cheers.
Posted on Aug 03, 2008
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
Inlet valve non operational on whirlpool awm 258 nordic
Please check on the voltage on the inlet valve , check on the controller if there is no voltage if not the inlet valve is faulty.
click this link: inlet valve
Jul 27, 2012 | Whirlpool Washing Machines
I require an operation manual for a Whirlpool AWM302
The Whirlpool UK site has support for the AWM 302. The direct link to the manual is http://docs.whirlpool.eu/_doc/501910006566GB.pdf . If this isn't your model, start at http://www.whirlpool.co.uk/support/instructions-for-use/instructions-for-use.content.html and click on Search. Then search using the Commercial code box. (There are also washers with the commercial code AWM 302/3 and AWM 302/4.)
I hope this helps.
Jun 03, 2012 | Whirlpool Washing Machines
I need a short program for washing and i lost the manual. i don t know how to program it
I have an AWM 5100 and the programs are printed on the outside of the detergent drawer, 1,2,3 prewash cotton, synthetic, delicates, 4 full wash,5 short wash cotton etc..this is not on your machine? Check the Whirlpool site, if no luck, reply here and I will see if I can help more..perhaps I can scan and email to you? but might not be same control options.. my machine also has a rapid wash button, which speeds any cycle.
Good luck
Jun 21, 2010 | Whirlpool AWM5125/1 Front Load Washer
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
I do not have a user manual for a Whirlpool AWM 1403 washing machine
Fixya,com doesnt offer Schematics or Manuals of any kind. You should try either GE for it or you can go and purchase one from www.manuals.com
Aug 25, 2009 | General Electric GE 15" Laundry Pedestal...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
