Question about Gigabyte GA-8ID533 Motherboard
It is an old motherboard and needs to be replaced where can i buy one
It freezes among many other issues as it is old and burnt out
Asus eee pc r101 burnt out
From the description the processor ic has overheated probably due to the cooling fan failing, this a serious motherboard failure and unless you have extended warranty, you are further ahead replacing the netbook.
Mar 22, 2012 | Computers & Internet
The unit freezes and does not cool until thawed
This sounds like one or all of these issues:
1. It could be due to lack of good airflow from the cooling coil because your air filter needs to be replaced.
2. You could just have an old compressor that needs to be replaced.
3. You could have a refigerant (freon) leak in your system, causing it to freeze.
The first issue can be fixed by yourself, when you replace your air filter, make sure you take note of the dimensions of the filter so you can buy the correct size. There will be an indicator as to which direction the filter should be facing on the side of the filter itself after you purchase it from your local home improvement store. If you replace your filter and the problem persists, you should call a liscenced professional to come out and assess the issue since the chemicals from the replacement of the compressor and fixing the refigerant leak can be harmful.
Aug 18, 2011 | Goodman CKL60AR60 Air Conditioner
My dell pc is 9 years old and all of a sudden it began freezing up. now it won't even boot up. the power light comes on yellow instead of green. i have taken memory out, video card out, and still...
Yes it could, check the motherboard for bulging/leaking capacitors (they're the round things that stick up), if you find any then that's probably your problem. They're easily replaced, but check that there's nothing burnt as that would make it more complicated and costly.
There's plenty of info on replacing bad caps on this site as well as many others.
Here's a few links:
Bad Capacitor FAQ - give you pretty much all the info you need, esp if you look around the site.
Farnell - Sells good quality capacitors.
Nov 26, 2010 | Dell Dimension 4700 PC Desktop
My ps3 wont read the games and when it does it freezes the game or simply just shuts off
It needs a new laser because the old one is "burnt out". It's a really common problem with them.
I buy mine at http://parts.consolerepairguy.com they run about $75 each.
I run a repair business and that place has best prices aside from Hong Kong which I don't trust.
Feb 08, 2010 | Sony Playstation 3 (PS3) Console
How to detect p5pe-vm mother board defective i have issue when i power on the p5pe-vm pc no dispaly noting ,no beep sound mother board getting power processor fan is running so how ICAN SOLVE THIS ISSUE...
Hi , Has your MB Sufferd any power Surges , Power Trips , or Shorting with Case of some sort? if so then your Motherboard is Burnt out , Try see if you can see any burnt marks , or Burst Capacitors .As soon as your CPU Fan runs , but your MB isnt running , you know its getting power ..So your motherboard is Burnt out, ASUS boards are very commonly , Burning out.I recently Sent mine back to ASUS because it burnt out..Also if you are going to take it in , make sure you have a proper qaulified Techie Checking it , otherwise they report that your CPU and PSU is also burnt out , and try get you to buy new from them...Becareful of that , its very common where im from.
Hope this Helps
Thanks
Dec 31, 2009 | ASUS P5PE-VM Motherboard
My ps3 is freezing while reading game disks, it
It rarely actually helps to clean the laser for the PS3. It needs a new laser because the old one is "burnt out". It's a really common problem with them.
Dec 26, 2009 | Sony PlayStation® 3 (80GB) Console
My machine just seems to freeze. I simply can not use it. I can't close or change cites.
does it happen regularly.
my old computer would run for 30 seconds when id turn it on and then freeze completly.the motherboard was gone
Aug 31, 2009 | Computers & Internet
Imac G5
Check the Memory9RAM) on your computer.
Jul 24, 2009 | Apple (661-2795) for iMac Motherboard
Computer keeps freezing and or turning off
same here but onlything any one would say to you would be to replace the motherboard that about it
2weeks after my warranty expired my mother board goes POOF!!
then shut off before it even hit the window screen
about the highest time it stay up was abuto 10secs then just turns off
May 16, 2008 | EliteGroup P4M800PRO-M Motherboard
Gigabyte GA-8ID533 Motherboard Logo
12 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
