Question about Duraflame Portable Tower Electric Heater
Twin star heater reads 99 for temperature
Temperature reads 99
Install heater control valve, 99 Chev astro van how to install heater control valve, 99 model
This year and model doesn't have a heater control valve it uses what is called an electrically actuated air temperature control blend door to control heated air and AC temperatures.
Feb 28, 2017 | Cars & Trucks
I have a twin star electric fire place model number 23EF023GRA that will not turn on at all from remote or switch and it is getting power. any ideas?
Jake not being smart here but have to ask how do you know it is getting power ? Just being plugged into a known good receptacle does not mean it is getting power.
If you know that power is actually getting into the fireplace then I would suggest a fuse is blown
It may not be a fuse as you know it but rather a temperature fuse for overheating
Oct 19, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Twin Star electric fireplace fan (maybe heater) doesn't work!
I have a twin star electric fireplace insert model #28efo24grs that is missing a remote any suggestions >>>>917-747-4893
Dec 13, 2009 | Kitchen Appliances - Others
Why wont my 99 chevy blazer temperature warm up?
You may have vapour lock in your heater lines. Start engine, put heat lever on high, disconnect one of the lines on your heater core, the one on the flow out side, & see if you have any air coming out. Once antifreese comes out stick line back on & retighten clamp. Make sure your cooling system is topped off. Also your water pump may not be functionihg to it's maximum. Take rad cap off cold & view flow rate. If inadequate you may have to replace the water pump. Good luck!
Dec 09, 2009 | 1999 Chevrolet Blazer
Rinnai EnergySaver 308FTR Turning off
A dirty filter will cause shut-off: is the FILTER lamp alight? Vacuum clean the filter if necessary. Are you sure you've set the timers properly? What temperature is set? LH figure is the desired temperature - RH side is temp measured by thermistor inside unit. If set too low, it turns heater off. Download the 308FTR manual here:http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/220.pdf Regards - Peter
Jul 02, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Duraflame Portable Tower Electric Heater Logo
57 people viewed this question
Top Duraflame Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Duraflame Heating and Cooling Expert? Answer questions, earn points and help others
