Question about Cerwin Vega IT-15.0 Car Subwoofer
Speaker box dimension cubic
What are the dimensions for a single 15 in. sub woofer box square box at 3.5 cubic feet
3 Suggested Answers
  • 74 Answers
SOURCE: box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Posted on Feb 17, 2009
  • 13 Answers
SOURCE: 2 15" and a 10" sub
10" subs need 1 cubic feet. 15" subs need 2.5 cubic feet. install them on its own volume of the box...
Posted on Jul 19, 2009
6000 cubic feet equals how many sq. feet
You can't convert cubic feet to square feet because cubic feet has an extra dimension, you could fit an unlimited number of square feet into cubic feet.
The formula for Cubic feet is:
length × width × height
The formula for Square feet is:
length × width
Aug 19, 2016 | Office Equipment & Supplies
How many cubic yards are in 557 square feet
Cubic is measured in 3 dimensions, and square is measured in 2 dimensions. Need to re-phrase question first.
Feb 28, 2015 | Office Equipment & Supplies
What r the parametric specs for the ma audio hk15x2
Fo (Hz) : 29.581 QMS : 3.965 QES : .517 QTS : .457
VAS (liters) : 147.723 REVC (Parallel-Ohms) 1 SPL @ 1 watt/ 1 meter (dB) : 90.6 X-Max Linear peak-peak (mm) 70 LEVC @ 1kHz (mH) : 1.043 Enclosure Volume (Sealed) : minimum 2 cubic feet Fill Required % : 0 3dB down point (-3dB) : 43 maximum sealed: 2.5 cubic feet n fill required: 39 at 3 dB down point Enclosure Volume Ported Vented (cubic feet) : 5.0 Vented to Hz: 35 3dB down point (-3dB Hz) : 28 Square port area Sq/In : 80 Port Length : 13" Power Handling : 2000 Watt RMS & 4000 Watt Max. Make sure to use MDF for the enclosure and use 1 inch thickness and use braces as well. This is a beast of a sub woofer. So give it the proper power it needs and make sure that your box is very solid in construction. If installed correctly and given the right power, this sub woofer is bound to put a smile on your face and rattle your bones. I hit 142dB with only one of these subs and im sure if i gave it more power i could hit the 150dB range. DON'T FORGET TO GIVE IT THE POWER IT DESERVES. Have fun dreamsystems.
Feb 16, 2011 | MA Audio HK15X2 Car Subwoofer
2 15" and a 10" sub
Jul 17, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Box dimensions for 15 in cerwin vega
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
What is the sealed and ported box volumes for the audiobahn dub 200 subs?
If you can access the inside of the sub box by removing the speaker, you may be able to measure the 3 dimension of each side of the enclosure.  1 cubic foot is 12x12x12 inches cubed.  That is 1728 cubic inches per cubic foot.  If you measure the inside dimensions of one of the enclosure sides as 10x14x8 inches, then that is 1120.  1120 divided by 1728 is 0.648 cubic feet.  Alternatively, you could estimate the volumes of each side of the box by measure the outside, figuring out where the box divider board is, subtracting the width of the boards used to make and then calculate.  Otherwise, I do not know the enclosure that that sub comes in.  Good luck.  Let us know how it goes.
Jan 02, 2009 | AudioBahn DUB200 Car Subwoofer
Dimension please for enclosure 12w3v2-d2
Typically you use one cubic foot per sub, so a 2 cubic foot box will work fine. To build a basic one, just a rectangular box, using 3/4" MDF (excellent material for a box), cut pieces this way:
2 - 25.5" x 13.5"
2 - 25.5" x 12"
2 - 12" x 12"
This will give you an interior volume of exactly 2 cubic feet. Cut your sub holes out of one of the 25.5" x 13.5" pieces.
Sep 24, 2008 | Jl Audio 12W3v2-D2 Car Subwoofer
Box dimensions
I've Got The Same Subs, I Got A Formula On The Net, Its Dimension Is Aprox 9 D X 24 H x15 W.
Although I Have Them In A Home Made Ported Box I've Made, Its Dimensions Are 8 D X 23 H X 17 W And Its Sound Pretty Damn Good. I Have A 2 Inch Round Port X 6 Inch Long. The Formula Says I Should Have A 3 Inch Long Tube.
Feb 23, 2008 | Volfenhag ZX-4712 Car Subwoofer
Enclosure type
Sealed box and somewhat large if they are 12's I usually try to get 3 cubic feet overall internal dimensions and generally the inside dimensions will be 13" tall 32" wide and 13"-14" inches deep. with no divider and make sure the box is sealed. Personally I like to phase the speakers backwards. Gives the bass a little more rumble.
Jan 05, 2007 | Sony XS-L1200B Car Subwoofer
Cerwin Vega IT-15.0 Car Subwoofer Logo
42 people viewed this question
Top Cerwin Vega Car Audio & Video Experts
xxxxxx xxx
Are you a Cerwin Vega Car Audio and Video Expert? Answer questions, earn points and help others
