Question about Ace Hardware Ace Staple Gun
How to load brads into staple gun - Ace Hardware Ace Staple Gun
2 Suggested Answers
jeff_drakesr
  • 155 Answers
SOURCE: I bought a used item #f509040 brad/staple gun (Air
The nails fit one side same place as the staples its usually on right side but may not matter. I hope this helps please rate if the answer helps in any way. Good Luck and have a great weekend.
Posted on Apr 03, 2010
How to load brads
My experience is limited with such things.
I have a couple of staple guns that will take brads, unfortunately the brads for one of them are no longer available. The brads had to have a shape and size similar one leg of the staple and a little of the bend at the top so they looked like an upside-down lower-case letter J and it was simply a matter of sliding a strip of brads into one side of the staple magazine.
The other staple gun will accept a more generic sort of brad in the same way but they have to be brads designed for use in that type of staple gun, known as a tacker so they aren't confused with the bigger staple/nail guns. The tacker will generally accept only brads of 20 or 18 gauge.
I suggest you ensure you have the right brads and then just load them like you would the staples.
Mar 28, 2016 | Tools & Hardware - Others
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
HOW TO LOAD BRADS IN STANLEY TRE500
Please download the instruction sheet from the following link which explains how to load the brads. Make sure you have the correct size of brads mentioned at the bottom of the instruction sheet.
TRE500 Sharpshooter Stapler Instruction Manual
Aug 13, 2014 | Electric Stanley Tre500 Staple Gun /...
Bt160hl stanly bostitch staple gun how do i load brads
I’m trying to buy brads, where can I buy the brads for this staple/Brad gun?
Jan 29, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
How to load brads into stanley tre 550 electric staple/brad nail gun
HOW TO USE YOUR ELECTRIC STAPLER/NAILER
TO LOAD STAPLES
1. Unplug tool, (fig. 1)...(place on/off switch in "off" position, (fig. 2).)
2. Place on/off switch in "off' position.
3. Select proper staple length.
4. Use only staples identified by stock numbers on next page. Substitute staples may cause jamming.
5. Hold tool upside down. (Squeeze latch and pull, (fig.3).)
6. Drop staples in channel, legs facing upward. Push latch back in to lock in place, (fig. 4).
TO LOAD BRADS
2. Use only brads identified by stock numbers on next page. Substitute brads will cause jamming.
3. Look for the image of a brad nail on the front side of the tool (fig. 5). Load brads into this side only.
4. Hold tool upside down (Squeeze latch and pull, (fig. 3).)
5. Drop brads into the channel, tilt the tool so the brads lay against the channel wall, (fig. 5).
Push the latch back in watching that the brad strip does not fall over.
6. Use High/Low power when driving brads.
TO STAPLE OR NAIL
1. Make sure the on/off switch is in the "off" position, plug stapling tacker in.
2. Turn tool on by switching to position 1 which is the "on" position and hold firmly against work surface to
engage safety mechanism.
3. Apply adequate pressure on the top of the knob (fig. 6.) while the trigger is pulled.
You can find the figures mentioned above at the following link:
http://bdk.force.com/FAQ/servlet/fileField?retURL=%2Fapex%2FPKB_Article%3Fid%3DkA0C0000000CdtPKAS%26brand%3DStanley%26returl%3D%252Fapex%252Fpkb_search%253Fbrand%253DStanley%2526mode%253D0%2526model%253D%2526sortby%253D0%2526terms%253DTRE550&entityId=ka0C0000000CdqqIAC&field=File_1__Body__s
Jun 20, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
Dont know how to load brads
You put the brads in along one side but otherwise they go in just like the staples. Mine is a different brand so I don't know which side for sure but if one side area is deeper that's the side the brads go on.
Mar 27, 2010 | Electric Stanley Tre500 Staple Gun /...
How do you load brads into the Arrow t50pbn staple gun?
Look at rear handle and push in tab then pull out load brads. Please Rate Thanks
Jan 08, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Installing brad nails
Pull the clip in the loader slot. Insert staples point side down. Slide loaded loader clip into place till you hear a click. You are now ready to staple! Enjoy, and make sure to staple the dog somewhere funny.
Oct 18, 2008 | Electric Stanley Tre500 Staple Gun /...
Ace Hardware Ace Staple Gun  Logo
Top Ace Hardware Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Ace Hardware Tool and Hardware - Other Expert? Answer questions, earn points and help others
