Question about Gigabyte GA-8ID533 Motherboard
The mother board keeps freezing
The screen keeps freezing even when turned on and off.
My screen turns white and freezes.
Sites blocked or incompatible. Screen freeze may be video card to includ video on the mother board. I had bad video on mother board. Screen freeze very frustrating. Couldn't figure the problem. Finally broke down and tried a new video card. Fixed, and upgraded.
Mar 18, 2015 | Dell Inspiron 560 Desktop Computer
Fridge keeps freezing up have replaced motherboard
What is the model number of your unit?
Nov 23, 2012 | Refrigerators
Freezer coils freezing up?
it could be the thermistor that is out of range or a bad mother board. the thermistor is not expensive. if you have a bad mother board it will do the same thing after you replace the thermistor. make sure you replace the th one attached to the evap coil.
Apr 08, 2012 | Hotpoint Refrigerators
Ever since I bought my new "KIng of the Hill" Ge
so try to install voltage regulator maybe it can affect on the main mother board operation bec. of power fluctuation observe unit after install automatic voltage regulator . if problem recurring mother board have problem or try to check the program setting.
Feb 05, 2011 | GE Profile PFCS1NJWSS Stainless Steel...
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
Toshiba Tecra M3 Laptop keeps freezing and shutting down, Can't even do Fresh Install on New Hard Disk Without Freezing, Have Replaced CPU Heatsink Compound.
What made you suspect the compund? You're probably right though. The fan has died or is too slow. The CPU and the video chip are what the fan is protecting. It might require a new CPU chip and fan. If it's the video chip, then a new mother board is in your future.
Good Luck
Mar 21, 2009 | Toshiba Tecra M3 Notebook
My xbox keeps freezing 20 minutes into a game of Halo Wars
Most likely your GPU has a broken solder point on the mother board.
Mar 08, 2009 | Microsoft Xbox 360 Console
Screen problem
you might have damaged the mother board. im a game consol repair service owner and personal what i would do is go to ebay and buy a new power switch first of all this will cost you about 10.00 and that covers shipping. install it your self correctly put the console back together give it a nice 4-5 hour charge and see what happens. also u could try popping the battery out for a hour and put it back in. you might have damaged the mother board and if so you need to buy a new mother board which will cost you 90-110.
if the power botton is broken is could cause the system to power on and off and maybe even freeze. fix the power botton
May 18, 2008 | Sony PlayStation Portable (PSP) Console
Computer keeps freezing and or turning off
same here but onlything any one would say to you would be to replace the motherboard that about it
2weeks after my warranty expired my mother board goes POOF!!
then shut off before it even hit the window screen
about the highest time it stay up was abuto 10secs then just turns off
May 16, 2008 | EliteGroup P4M800PRO-M Motherboard
Gigabyte GA-8ID533 Motherboard Logo
13 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
