Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
Cant remove trimmer head from homelite st155 trimmer
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
  • 4 Answers
SOURCE: cant get the spool off homelite trimmer
Unscrew the bump-knob and the rest pulls off. If it won't unscrew you could always cut it off and buy a new one from ALM Manufacturing 01423 797208
Posted on Jun 01, 2009
  • 81 Answers
SOURCE: Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Posted on Jun 17, 2009
SOURCE: removing spool from homelite 13 inch electric trimmer
The entire cap does not come off. You push the buttons in on each side and only the very top of the cap comes off.
Posted on Jul 23, 2009
  • 54 Answers
SOURCE: Have a Homelite gas trimmer. Cannot remove the
Not sure but have you checked to see if it might be left handed thread
Posted on Apr 26, 2010
How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Jul 12, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
MY HOMELITE STRING TRIMMER UT21505 PRIMER BULB LEAKS. MY PARTS LIST DOE'S NOT SHOW THIS PART. CAN I PUCHASE IT OR DO I HAVE TO THROW IT AWAY
You can easily get a new primer bulb for it...most small engine repair shops will have what you need, and if you want, you can most likely snag one on Ebay....DON'T THROW IT AWAY, ok?
Jul 10, 2010 | Homelite Mighty Lite Lawn Trimmer
What is the right size trimming cord for the st 155
On the spool you should be able to find the size. Look for decimal sizes; .065, .080. etc... That will be the correct size...Lee
Apr 01, 2010 | Homelite Mighty Lite Lawn Trimmer
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
To remove head to refill line which way do I turn bumper knob?
As a general rule it is right hand threads on curved shaft trimmers and left hand threads on straight shaft trimmers. The major exception is on homelite manufactured units. On Homelite units the black bump knob is right hand and the red bump knob is left hand
Sep 20, 2009 | Garden
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
47 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
