Question about Motorola For MT2000 HT1000 HT6000 GP900 JT1000 GP1200 MOBIUS MTX8000 MTX9000 MTS2000 7.5v 1300mAh NiCd Intrin... 2-Way Radio
Motorola pr400 radio will not talk to other pr 400 radio
Why does my motorola cp200 speaker mic plug have intermittent connection?
The internal jack on the radio has a bad solder connection on it, very common problem in that model. Take it to a Motorola shop for repair.
Jun 07, 2014 | Motorola Speaker Mic Pmmn4013a Cp200 Gp300...
How do i remove the circuit board in the BPR40
PeteD.
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Mar 13, 2014 | Motorola Headset Mic Vl130 Pr400 Bpr40...
I have one microtalk radios PR 4500 (because I lost the other) and I thought to buy another pair of radios . My question is: should I buy exact type of radio to work with what I have or I can buy...
You may want to Buy the same thing, Go to store with yours, Have it turned on, When checking all they have, turn theirs on to see if you get good reseption
Aug 27, 2013 | Cobra MicroTalk PR 1100 WX (15 Channels)...
How do i figure out if my motorola pr400 is uhf or vhf
Model number:
AAH**K is VHF
AAH**R is UHF
AAH**S is UHF
Best regards.
Jan 30, 2013 | Radio Communications
Are motorola HT1250 handheld radios narrowband capable? How about PR 400's?
Yes, and yes. Both radios are programmable to either narrowband or wideband.
Best regards.
Mar 29, 2011 | Motorola Mag One BPR40 Two Way Radio
I need to know if I can fix an eprm err with the
An eeprom error can occur during programming due to several factors, it may have been as simple as a momentary glitch in the computer, radio or cable, or other unknown cause. Once you've discovered the error, you need to get rid of any saved codeplugs associated with the problem radio. You can try cloning another radio's codeplug back into the unit to see if it clears the error. If this does not work, there is nothing you can do using the CPS software to resolve the error. The radio would need to go back to the Motorola factory depot or a qualified/experienced service facility to have the error cleared and have the radio reprogrammed.
Best regards.
Mar 12, 2010 | Motorola EM1000R Two Way Radio
Cobra microtalk Pr 17 OC
Dear sir,
Open the unit & check PTT switch check it by manually closing the circuit ..it will come in tranmission mode .i think ur PTT switch is out of order & nothing else .
Regards
Raj
Dec 11, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
PROGRAMMING
here is a link to the manual for your radio (english http://myweb.accessus.net/~090/bearcatting.html#motoman They do not give out the information of how to program it, only authorised technicians are permitted to do so. Here is the link to motorola customer support in Puerto Rico https://www.motorola.com/pr/feedback.jsp They should be able to tell you where you can get your radio programmed, and what programming is permitted in PR. Hope this helps :)
Mar 21, 2007 | Motorola For MT1000 MTX800 MTX90010v...
Radio Communications Logo
27 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
