tanx fo dee info...looks like I'll be getting a new washer sometime in the near future.tanx fo dee info...looks like I'll be getting a new washer sometime in the near future.
You can't post conmments that contain an email address.
The noise coming from this machine as it spins is due to --If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing. Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job... A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad... Picture1 - Picture2 The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like... Picture1 - Picture2 - Picture3 I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it. Picture1 ( boot pushed inside ) Help page1 - Help page2
Big problem with front load washers the tub bearing more than likely seized replace the machine the parts and labor close to 1000 I fix these all day long under warranty.
The spin bearing or basket drive maybe worn or seized. Lubrication maybe needed. The motor starting torque is not sufficient to spin the tub during start-up. Check also the motor rotor. When turned by hand, it must spin freely. Lubricate if necessary. Otherwise the bearings/bushings are worn out and needs alignment or replacement. You may need the service of a qualified appliance repair technician.
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
