Question about Motorola Mobility L6 Cellular Phone
Image on screen
The screen on my sons phone has suddenly started showing a strange image, which is there permantly. Its in the middle of the screen and is bright yellow. It looks like a pile of straw. there doesnt appear to be anything else wrong with the phone, just this image over the top of his wallpaper.
  • 94 Answers
Yes... The LCD screen is faulty and will have to be replaced in order to remove the "pile of straw" , You can do this by removing the screws below the battery with a t7 torx screwdriver , then you will be able to remove the front of the phone and ther you will see the LCD screen and is simple to replace, Hope i helped :~)
Posted on Oct 20, 2007
SOURCE:
My screen on the lg vx5500 cell phone is making strange shapes. When the phone starts up, the bottom half of the screen shows what should be on the top, and the top half is just a white screen. When I...
Your problem is caused by the communication foil between the LCD and the mainboard of the phone. This foil contains a number of circuits that makes data transfer possible. The one or more circuits do not communicate anymore, the phone displays odd images.
Nov 07, 2010 | LG VX5500 Cell Phone
Sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
Shows gray screen on all channels
between image controls, (contrast-brightness-colour), Check the "colour" setting. should be near the middle of it's way.
if an automatic scan was performed before the event, please start it again, but assure proper country selection when asked (or better, check if there is a country selection menu and have it set to your country BEFORE starting the autoscan.
Aug 31, 2009 | JVC AV-27050 TV
HP Scanjet 5590 scans inmage on other side of paper on ADF Ok on flat bed
Really strange! May be the brightness is not controlled in the ADF mode, too bright to scan data on the backside also. Try reinstallig the software.
S. Mohan
Aug 18, 2008 | HP Scanjet 5590 Flatbed Scanner
Kyocera K404 with Verizon - HELP
it almost sounds like the lcd is bad on the phone
Jan 06, 2008 | Kyocera Switchback KX21 Cellular Phone
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Burn in
The bad news is generally crt burn in is a permant condition. the only way is to replace crt.. these are not easy or cheap. on average it takes me more than hour to repace one tube and with 3 around 2 . dissambly is tough on this set. the tubes cost about 250 apeice. now times 3 plus labor .. i generally recomend if you have to replace all three its not worth is these setts are 800 at walmart.
Sep 23, 2007 | RCA HD52W59 HDTV Projection Television
Won't record picture
it probably is the ccd imager. call sony and tell them about the problem. since they had a recall for this issue the may fix it for free.
Jun 11, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Motorola Mobility L6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
