Question about Kenmore 36 in. 33384 / 33385 / 33389 Gas Cooktop
Gas Cooktop One burner takes long time to ignite can I adjust this?
  • agmanagman Jan 31, 2008
    Problem was the burner need to be screwed down tighter to put the sparker- a fraction of an centimeter closer to the heat deflector
  • 473 Answers
It is probably just a dirty orifice. It should be in the center of the burner and have a small hole in the top of it. Use something small like a paper clip or safety pin and poke in that hole a few times to clean it out. Let me know if this helps.
Posted on Oct 10, 2007
SOURCE:
My DGSU100-4BSS-LP Gas Cooktop spaks but does not ignite
Check for LP leak. You also have to wait for air locks to vent out through burners to get lite the first time.
Jul 29, 2012 | Viking 31 in. DGSU100-4BSS-LP Gas Cooktop
My GE Gas cooktop model # JGP975EKSS is trying to ignite without any burners being turned on.
If all the burners are trying to ignite at the same time - the ignitor module is to blame.
If it is one specific burner - take a look at that individual knob.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 04, 2010 | GE Profile JGP636 Gas Cooktop
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Aug 26, 2009 | Miele 35 in. KM326G Gas Cooktop
Gas cooktop BOOM
Gas is taking too long to ignite. Make sure the burner rings are installed properly. They have grooves that need to line up. Also make sure all the holes are clean.
Apr 03, 2008 | Cooktops
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
May 06, 2007 | Miele 36 in. KM342 Gas Cooktop
Some Burners Will Not Ignite
probably a worn wire to the electrode or a cracked ignitor. you are faced with taking off the hobtop and looking - no easy solution. you should not do this unless you are confident and don't interupt the gas path
Apr 06, 2007 | Dacor Preference SGM466 Gas Cooktop
Kenmore 36 in. 33384 / 33385 / 33389 Gas Cooktop Logo
71 people viewed this question
Top Kenmore Cooktops Experts
jdthefixer
mcgsp
Level 1 Expert
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
