Question about Coaster Round Storage Ottoman in Black Finish 501010
Need assembly instructions
Instruction are not clear where leg go
I'm looking for the Velbon Videomate 601 instruction manual for my tripod.
Is a manual or instruction leaflet really necessary ? Tripods are actually amazingly simple to use. You spread the three legs (three legs - 'tri'-pod) and place them firmly on level ground. Then you attach the camera, camcorder, spotting scope or whatever to the top, and use the equipment as desired.
Sep 13, 2017 | Velbon Photography
Need instruction manual
Hello clarence
Why do you need and instruction manual? Legs go up and down, the heads tilts and pans, the head also has adjustment for level.
Dec 02, 2015 | Photography
How to put the legs on flutterbye dream swing
Request instructions directly from Flutterbye.
Jan 25, 2015 | Toys
I need instruction manual for manfrotto 058b tripod
There is a red slider under the main casting that will release the legs all together.
Apr 13, 2013 | Manfrotto 058b Triatt Camera Tripod Black
I need an instruction manual for aerial home gym. model no:50800. Have been given gym, but its in pieces. need the instruction manual so we can assemble it.
Email me at petethebutcher@hotmail.com and I can send you a photo of assembled item and may be able to instruct you from there
Regards Pete
Jun 25, 2011 | Sport & Outdoor - Others
I need a leg for the dwell studio silver lake crib in espresso/white. mine came with two of the same sided legs and the bed can't be put together until I find the opposite leg. Does anyone know how to get...
I am also missing one leg, and mine came with two of the same legs. I am missing part D. I contaced the manufacturer and they said it will take 4-6 weeks to get the part!!!
Mar 20, 2010 | Storkcraft Baby DwellStudio for Target...
Need to assemble a J Mason surround play yard properly
Hi there. I assume it's the same one I have, and I have to say, it's the best! Totally safe...can't see any reason it could be unsafe.
First, underneath the nylon part, you'll find 4 legs in "pockets". Take them out, and (obviously) one goes in each corner. Insert one at a time (I typically do diagonals to keep it upright, but it doesn't matter), making sure to put them through the mesh corners. Simply screw each into the top of the playyard.
I believe there are also some nylon "flaps" that you can re-velcro underneath the playyard (writing this from memory).
Most important is to make sure that the legs are securely screwed in and that they are through the mesh.
Hope that helps.....
May 18, 2009 | J Mason Baby Gear
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
3 in 1 Exersaucer Pond Stage 3
Go to www.evenflo.com. Click on your product at the top and then on the right side there is a "related link" for product instructions. You will need your Model # and Manufacture date (which is on the seat of the Exersaucer). Then it will list all the parts available for that product. Almost all the way down is a pdf version of the instructions that you can download for free. I used it and was able to assemble my Exersaucer to the 3rd stage. Good Luck!
Dec 22, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Coaster Round Storage Ottoman in Black Finish 501010 Logo
579 people viewed this question
Top Coaster Furniture Experts
ray gallant
Are you a Coaster Furniture Expert? Answer questions, earn points and help others
