Question about Whirlpool GI6FDRXXY
Ice maker not working no water
Ice maker not working less than two years old
  • 65 Answers
SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Posted on Feb 16, 2008
  • 1073 Answers
SOURCE: Just replaced the ice maker
replace the water inlet valve
Posted on Jun 10, 2008
tech master
  • 120 Answers
SOURCE: no water to the Ice Maker
sorry to hear that i hope i still can help check the fill tube that fills your ice maker see if it is frozen if it defroated with a hair dryer if there is no frost then you might have a bad water valve you see there are 2 selenoids on valve one for dispenser and the other one for the ice maker so if you don't get water it could be the valve look at the ice maker are the forks pointing up or down if they are down then you have a bad module on ice maker that is the front part of it. if they are pointing to 1oclock then check valve and tube
Posted on Oct 16, 2008
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Posted on Mar 26, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
Ice Maker not working after replacing IceMaker and Inlet Valve. Any other ideas?
Hi. I am sorry that your ice maker is not working. Hereis a link to schedule a service call: http://bit.ly/yLv4Z5 . I hope this information is helpful. Sincerely, Melanie, Whirlpool Social media group.
Jun 19, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a subzero BI42 SD fridge. Just replace the water filter. It now does not make ice. Turned on the icemaker but get a blinking ice indicator on the control panel. Looked into the trouble shooting...
this is abrand new fridge.if the ref is less than 2 yr old. better call a tech. your problem FOR SURE. water valve, ice maker, or a combination of 2. also tell your tech. to check the arm in the i.m. and the brackett. do not trty to replace the ice maker. is a little tricki.(SUBZ.less than 2 years old is cover by the manufactor subzero. zero money for you.)
Apr 19, 2010 | Sub-Zero Bottom Freezer Refrigerator
Our brand new 3 door 25' LG has stopped producing ice. The switch is ''on'', and water dispenser works. The motor operates to send either cubes or crushed ice out the dispenser, but NO ICE. What do I look...
LG has problems with there ice makers. if is less than a year old it is under warrenty--even if you dont have a reciept. sounds like the ice maker needs replaced. i have replaced several that were less than a year old.
Oct 28, 2009 | Refrigerators
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker does not work this is less than a year old and it has stoped working water is on as the water side works
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 08, 2009 | Refrigerators
Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Mar 10, 2009 | Fisher and Paykel E522B Stainless Steel...
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool GI6FDRXXY Logo
63 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
