Question about Power Center Jumpstart 11-411
Mass and wieght mass of the dog - Power Center Jumpstart 11-411
How do i calibrate a FX650C without wieghts
it needs weights of set mass to be able to calibrate
simple weights are packaged items like sugar frozen vegs etc
anything with the weights printed on the outside and the thinner the packaging material ( paper, plastic) the better as the weight of the packaging material ( glass steel etc) will affect the calibration
Mar 05, 2017 | Office Equipment & Supplies
Tip
Right way to feed a senior dog
Dogs are considered seniors in the last third of their life. During this time, it is important feed them a well-balanced diet that will help them maintain good health and an ideal bodyweight. Just like humans, as dogs age, they are prone to more and more health risks like arthritis and obesity. What should senior dogs eat? One of the most important ingredients for senior dogs is protein. They must eat a good portion of protein because older dogs tend to lose muscle mass.As far as fat goes, senior dogs need to eat less fat. Another thing senior dogs should eat is fruits and vegetables because they help fight constipation. When it comes to calories, senior dogs must eat less in order to maintain their bodyweight. Finally, consider supplementing your senior dog with vitamins/minerals as they can be beneficial to your dog.
on Aug 06, 2012 | Dogs
Is dog and cat food made from other dogs and cats that have been killed at shelters
Nooooooooooooooooooooooo and you are disgusting for ever thinking about that!!!!!!!!!!!!!!!!!!!!!!!!
Feb 28, 2015 | Cats
How do you train a dog to be more confident
My solution is for Human treats, not for dogs. These are fudge brownies. Which are onolicious! I need a representative. to mass produce this recipe. Please!
Sep 22, 2013 | Dogs
Wieght watchers scale WW-87 What does P-1 one
P-1 means "Person 1". It has spaces for 10 entries.
Jun 17, 2011 | Conair Weight Watchers WW-87 Body Fat...
WHAT IS IT'S SHIPPING WIEGHT
hi,
Its shipping wieght is 368 lb, arround 166.92 kg
ok
Apr 29, 2011 | Pioneer PRO-710HD 64" Rear Projection...
I want to know how tight to tighten the bolts on the clutch pressure plate? Thankyou.
The bolts should be 12 mm. The manufactures don't usually give tightening tourques for the clutch cover but I think if you take them to 23nm you'll be fine. Make sure that you check them for stetch before fitting them and as its a rotating mass, make sure they're all same sizi and wieght. There should be a number on the head of each, check to make sure the same number or symbol appeares on all. Regards Johngee
Oct 03, 2010 | Mitsubishi Pickup Cars & Trucks
Washer will not spin with very light loads or heavy loads (i.e. cotton bath matt). Must be mfg. defect, has done this since I bought it apparently, but was months before I had wash one article by itself....
Hi, Actually the "fix" for the problem you described is quite simple and not a manufacturer's defect at all. You must add another item of similar or equal mass/wieght. Most front load washer's will never reach their true spin potential with only one item in the basket, they aren't designed to. The motor "dyno" measures the balance of the load by way of resistance or if you like "wieght differential". If the dyno consistently senses more wieght on either side of the basket it will advance to the "off" position and subsiquently "skip" the spin, hence saving your washer from major damage. This is a good feature trust me. Try that out, I hope it helps you and explains why sometimes the washer doesn't spin the clothing/articles out satisfactorially. Good Luck :)
Oct 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Hiya i just done the forkseals on my xr125-2006 , does anybody know the quantity of fork oil to go back in i got oil grade10
dont use 10 wieght its stiff as can be i recomend 7.5 or 5 wieght but a quart in each fork will do.
Jun 16, 2009 | 2006 Honda XR 125 L
Balance beam scale
First, with scale empty, set all wieghts to their zero positions. Set zero adjustment so that the indicator is on zero. Place sample on scale and, working from heaviest to lightest, set each wieght to one notch less than what would overange indicator. When all wieghts have been set add the values of each wieght position.
Oct 23, 2008 | Baby Gear
Power Center Jumpstart 11-411 Logo
19 people viewed this question
Top TREND Vehicle Parts & Accessories Experts
Lawrence Oravetz
ray gallant
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a TREND Vehicle Part and Accessory Expert? Answer questions, earn points and help others
