Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Shortcut How can i make a new folder in explorer using ashortcut key combination?
  • Chotka Oct 10, 2007
    Its not my sol yaar All knew it.
    U r using the menu
    i m asking abt the shortcut key
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
To create a folder with shortcut key combination in windows explorer press Alt (and while it is pressed) press F W F
Posted on Oct 09, 2007
SOURCE:
Start
Computers often use shortcut links to make it easier for users to locate and open files.
These links are commonly placed in a folder easily accessible to users, such as a desktop folder.
When a shortcut is created, it is given directory information and an icon.
If the file associated with a shortcut is later moved, the shortcut may fail to locate the file.
When this problem occurs, you need to update the shortcut's directory information.
This process is often automated by operating systems, but in a some instances, you need to repair shortcuts manually
Right-click on a broken shortcut link's icon.
Select the "Properties" option. Locate the "Target" box and copy its information into your clipboard using the Ctrl and C keys.
Open the "My Computer" folder on your computer and paste the target information into the folder's address bar using the Ctrl and V keys.
If the address bar is not viewable, you may need to enable it in the folder's settings.
Find address bar options in the "View" menu under "Toolbars."
The file's target path folder will open.
Locate the file in the target path folder.
If the file is not present, the target path is inaccurate and likely the cause of the shortcut link error.
Locate the file in its correct folder.
Browse folders or search for the file by typing the file name into the "Start" menu.
After finding the file, open the properties of the shortcut link icon again.
Copy the file's correct path, from the containing folder's address bar, and paste it in to the "Target" box, replacing the incorrect link.
Another way to find a file's target path is by right clicking on the file and selecting Properties.
You can find accurate target information in the "Target" box, provided the icon is the original file icon and not a shortcut.
Jun 07, 2013 | IwantSoft Free Keylogger
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
Tip
Recreate the Show Desktop icon on the Quick Launch toolbar
To re-create the Show Desktop icon on the Quick Launch
toolbar, follow these steps....
1. Use any text editor (such as Notepad) to create a
file with the following lines:
[Shell]
Command=2
IconFile=explorer.exe,3
[Taskbar]
Command=ToggleDesktop
2. Save the new file as a file named Show Desktop.scf
in the WindowsSystem or WinntSystem32 folder. Note
that Notepad may automatically append a .txt extension
to the file name. Remove this extension if Notepad
adds it. These steps do not work if the file is named
Show Desktop.scf.txt.
3. Quit Notepad.
4. Using Windows Explorer or My Computer, right-click
the Show Desktop .scf file, and then click Create
Shortcut.
5. Copy the new shortcut to the appropriate folder. In
Microsoft Windows 95 or Windows 98, copy the shortcut
to this folder: WindowsApplication DataMicrosoftInternet
ExplorerQuick Launch
In Microsoft Windows NT or Microsoft Windows 2000,
copy the shortcut to this folder: WinNTSystem32
In Microsoft Windows XP, copy the shortcut to the
following folder: WINDOWSSystem32ConfigSystemprofileApplication
DataMicrosoftInternet ExplorerQuick Launch
6. Rename the shortcut to Desktop.
The Show Desktop icon automatically appears on the
Quick Launch toolbar.
Reference:
http://support.microsoft.com/kb/190355/EN-US/
on Jun 24, 2010 | Microsoft Windows XP Professional SP2
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    I accidentally deleted the internet explorer icon shortcut; how do i get it back?
    Assume you are using Windows XP..
    Go to My Computer >C Drive (your hard drive icon)>open programmes, find the Internet explorer folder, open it and right click on the "iexplore" icon and create shortcut..it will then prompt you to place the shortcut on the desktop..windows Vista is virtually the same
    Feb 10, 2010 | Microsoft Windows Vista Home Premium...
    Tip
    Windows keyboad shortcut
    When speed counts, the keyboard is still king. Almost all the actions and commands you can perform with a mouse you can perform faster using combinations of keys on your keyboard. These simple keyboard shortcuts can get you where you want to go faster than several clicks of a mouse. You'll work faster on spreadsheets and similar documents, too, because you won't lose your place switching back and forth between mouse and keys.
    Here are some of the most useful keyboard shortcuts:
    Copy. CTRL+C
    Cut. CTRL+X
    Paste. CTRL+V
    Undo. CTRL+Z
    Delete. DELETE
    Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE
    Copy selected item. CTRL while dragging an item
    Create shortcut to selected item. CTRL+SHIFT while dragging an item
    Rename selected item. F2
    Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW
    Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW
    Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW
    Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW
    Highlight a block of text. CTRL+SHIFT with any of the arrow keys
    Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys
    Select all. CTRL+A
    Search for a file or folder. F3
    View properties for the selected item. ALT+ENTER
    Close the active item, or quit the active program. ALT+F4
    Opens the shortcut menu for the active window. ALT+SPACEBAR
    Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4
    Switch between open items. ALT+TAB
    Cycle through items in the order they were opened. ALT+ESC
    Cycle through screen elements in a window or on the desktop. F6
    Display the Address bar list in My Computer or Windows Explorer. F4
    Display the shortcut menu for the selected item. SHIFT+F10
    Display the System menu for the active window. ALT+SPACEBAR
    Display the Start menu. CTRL+ESC
    Display the corresponding menu. ALT+Underlined letter in a menu name
    Carry out the corresponding command. Underlined letter in a command name on an open menu
    Activate the menu bar in the active program. F10
    Open the next menu to the right, or open a submenu. RIGHT ARROW
    Open the next menu to the left, or close a submenu. LEFT ARROW
    Refresh the active window. F5
    View the folder one level up in My Computer or Windows Explorer. BACKSPACE
    Cancel the current task. ESC
    SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.
    Use these keyboard shortcuts for dialog boxes:
    Move forward through tabs. CTRL+TAB
    Move backward through tabs. CTRL+SHIFT+TAB
    Move forward through options. TAB
    Move backward through options. SHIFT+TAB
    Carry out the corresponding command or select the corresponding option. ALT+Underlined letter
    Carry out the command for the active option or button. ENTER
    Select or clear the check box if the active option is a check box. SPACEBAR
    Select a button if the active option is a group of option buttons. Arrow keys
    Display Help. F1
    Display the items in the active list. F4
    Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE
    If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts:
    Display or hide the Start menu.
    Display the System Properties dialog box. +BREAK
    Show the desktop. +D
    Minimize all windows. +M
    Restores minimized windows. +Shift+M
    Open My Computer. +E
    Search for a file or folder. +F
    Search for computers. CTRL+ +F
    Display Windows Help. +F1
    Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. + L
    Open the Run dialog box. +R
    Open Utility Manager. +U
    Helpful accessibility keyboard shortcuts:
    Switch FilterKeys on and off. Right SHIFT for eight seconds
    Switch High Contrast on and off. Left ALT +left SHIFT +PRINT SCREEN
    Switch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCK
    Switch StickyKeys on and off. SHIFT five times
    Switch ToggleKeys on and off. NUM LOCK for five seconds
    Keyboard shortcuts you can use with Windows Explorer:
    Display the bottom of the active window. END
    Display the top of the active window. HOME
    Display all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)
    Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)
    Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)
    Collapse current selection if it's expanded, or select parent folder. LEFT ARROW
    Display current selection if it's collapsed, or select first subfolder. RIGHT ARROW
    on May 23, 2010 | Computers & Internet
    Tip
    Shortcut keys
    Some of the advanced features of windows allows shortcut keys these keys allow you to open applications faster this is a list of key combination and what they do the first set of shortcut keys and mostly designed for text applications such as notepad Microsoft word wordpad and any other text input application the first set of combinations keys are CTRL key and the letter C at the same time this allows you to copy highlighted text the next combination of keys are CTRL key and the letter V this allows you to paste that copy text you copy using CTRL C into text application or any application that uses keyboard input the next set of combination keys are CTRL P this allows you to print the current text document just as you would if you went file print the next set of keys are more designed for windows application shortcuts if you're on your desktop and you want to open the run dialog box that holds the windows key and press the letter R and you'll see the run dialog box here you can type in locations of files and open them through the run dialog box the next short cut key the allows you to open explore not to be confused with Internet explorer, that explore application is what opens up when you click on my computer my documents and the anything else to view folders files hard drives pictures movies and music or anything else that's inside a folder that the shortcut key to access this is the windows key and E at the same time it should open my computer because this is the main explore application the next key combination of more for advanced users CTRL+ Alt+delete this key combination accesses the task manager program which shows the process list the CPU usage and programs that are open and network activity this program allows you to end processes and programs that are frozen and do not recommend ending any processes that you're on not familiar with this may cause a computer crash or you lose data but ending application from the application view is OK if the applications is frozen because the computer will automatically end the applications processed for you safely as Microsoft has updated to windows Vista and windows 7 they'v added a new feature called the Arua effect if your computer is new or you have a compatible graphics card by pressing the windows key and the tab key at the same time will allow you to scroll through all the open applications in a 3D window this next set is mostly for laptops on laptops on the keyboard there's a key labeled FN which is short for function each laptop is different but in small print on the main keys you should notice little letters symbols or numbers are holding the function key and pressing one of these keys that have one of the symbols letters or numbers will allow you to access the secondary feature the keyboard as soon as you let go of the function key the keyboard returns to normal for example most computers will have a sun symbol on the up and down arrow keys this allows you to adjust the laptops brightness all you have to do is hold the FN key and press one of the arrow keys and you can turn the brightness of your screen up or down these are some of the few shortcut keys and you can do with windows there are many more hope this tutorial helps
    on Jan 23, 2010 | Computers & Internet
    How do i open a new browser
    You can open a new browser window from these locations :
    1. Start -> Programs -> Internet Explorer / Mozilla Firefox.
    2. Double-Click the "Internet Explorer / Mozilla" shortcut icon in the 'Desktop'.
    3. Click on the "Internet Explorer / Mozilla" shortcut icon in the 'Quick Launch' (Left Side of Task Bar).
    4. If a browser window is already open, try "Ctrl+N"!
    if it helps tell me....tc! :)
    Jan 02, 2010 | Computers & Internet
    Tip
    Set a new Windows Explorer launch folder When you run Windows Explorer, it...
    Set a new Windows Explorer launch folder When you run Windows Explorer, it always opens to the Libraries folder. That's fine if you use Microsoft's default file organization, which designates Libraries as the overall container for your folders. But what if you don't? You might prefer to have Windows Explorer open to Computer or any other folder you choose. Here's how to do it:
    1. Right-click the Windows Explorer icon on the taskbar (it's the one that looks like a folder), and then right-click the Windows Explorer icon from the context menu that appears and select Properties. The Windows Explorer Properties dialog box appears.
    2. You'll have to edit the Target field on the Shortcut tab of this dialog box in order to change the default location at which Explorer opens.
    If you want Explorer to open to a specific folder, simply enter the name of the folder, substituting your folder name for Folder, below, like this:
    %windir%\explorer.exe c:\Folder
    So to open Explorer to the folder named Budget, you would type this in the Target field:
    %windir%\explorer.exe c:\Budget
    If you want Explorer to open to special, pre-set locations, such as Computer, you'll need to enter special syntax in the Target field. Following is a list of three common locations and the syntax to use, followed by the syntax for the Libraries folder in case you ever want to revert to the default.
    • Computer: %windir%\explorer.exe ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}
    • My Documents:%windir%\explorer.exe ::{450D8FBA-AD25-11D0-98A8-0800361B1103}
    • Network: %windir%\explorer.exe ::{208D2C60-3AEA-1069-A2D7-08002B30309D}
    • Libraries: %SystemRoot%\explorer.exe
    3. After you've changed the Target field, click OK. Next time you launch Windows Explorer, it will open to the new location you've designated.
    on Jan 12, 2010 | Computers & Internet
    Tip
    Create a shortcut key for Internet web pages
    Create a PC shortcut key to a favorite web page by following the below steps.
    Internet Explorer users
    Users using Internet Explorer can quickly do this by right-clicking on an empty spot of a web page and click 'Create Shortcut'.
    Other Internet browser users
    If your browser window is maximized make it a window. Once done click and drag the icon next to the URL and drag it to your desktop or other location you wish to create the shortcut.
    After shortcut has been created
    Once the shortcut has been created locate the shortcut and right-click it and click Properties. In the shortcut properties assign a new shortcut key and click OK. Now when the shortcut key is pressed the web page will be automatically loaded.
    on Jan 04, 2010 | Computers & Internet
    Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
    48 people viewed this question
    Top Microsoft Computers & Internet Experts
    Ekse
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
