Question about Clear Screen Protector - ZTE Avid 4G N9120
Power button is broken
The power button wont work anymore. can i replace it myself?
How do I fix the broken release button for the handbrake?
Check with a Ford dealer regarding replacement. This is a safety issue and should be taken care of promptly.
Jul 16, 2014 | 2001 Ford Focus
Kenmore dryer wont start tab broken
Yes that is the lever for the door safety switch. It can be fixed easily,
I have repair pictures and home made video on Kenmore dryers HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 02, 2012 | Kenmore Dryers
Folding button detach
Hi Frank - Glad to hear that you've managed to rectify that issue!
Nov 27, 2011 | Quinny Baby Gear
The on off button is not working anymore on my shark garment steamer anymore
The button itself may be bad. The plug end of the power cord may have a broken wire near the plug--repair with a common replacement plug from a home center or hardware store. An AC voltmeter would be a great help in finding the problem instead of just replacing parts until it works. Good luck!
Sep 26, 2010 | Vacuums
My power button doesnt work anymore
Mine turns on when I plug the charger into it. Have you tried that?
Jul 04, 2010 | HTC Hero Smartphone
I have a toshiba tv with a broken power button
Generally the power button has to be on first to put the TV in standby mode. If you cant do this no remote can ever work. Remotes are not capable of turning on a set that has no power mechanically turned off. and that is what the master switch does. once that standby light is off it is not live and consuming power and not under the control of a remote anymore
please rate our help++++Y=Thanks for using FIXYA
Sep 25, 2009 | Sharp 27N-S100 27" TV
Remote wont change to vid1, vid2 please help
The GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.
May 21, 2009 | iLO IWT3206 TV
The screen wont turn on anymore. the buttons can sometimes but the screen stays black.
When you say the buttons "sometimes" lite up, do you mean just when they feel like it or only when you power it up or off? And is it making any noise when you power it up? If they're only working when you turn it on and then they go off, then you have a firmware problem and you need to have it re-flashed.. If they turn on and stay on, and it makes noises (like you can hear the keytones when ya press them) then it has got a bad LCD and that's a pretty inexpensive fix (check Ebay for a replacement screen)
May 20, 2009 | Motorola Cell Phones
Broken glass door
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Jan 01, 2009 | Zanussi ZBQ365 Electric Single Oven
Wont play dvd
yes there is a rset button u just have to gift me  ur ps3 and ill do it 4 myself best sol 4ever
Jul 21, 2008 | Sony PlayStation Portable (PSP) Console
Clear Screen Protector - ZTE Avid 4G N9120 Logo
Top Clear Electronics - Others Experts
Are you a Clear Electronics - Other Expert? Answer questions, earn points and help others
