Question about Philips 27PT6441 27" TV
Size fuse for toshiba model pdp42x32000 - Philips 27PT6441 27" TV
Need to know the size of screws that goes into TV stand for a Toshiba TV model number 40S51u
58 cents each mail order. Not only do they have to be right diameter and thread, also the correct length.
40S51U Toshiba Tv, 40" 1080P Led Lcd Replacement Parts
https://www.encompassparts.com/model/TBA40S51U/_/_/Toshiba/40S51U/Tv,_40
  1. Cached
Toshiba from Encompass parts & accessories. ... 40S51U Toshiba Tv, 40" 1080P Led Lcd. 40S51U Tv, 40 ... 75024004, Toshiba Screw, Stand, Mac000, 0.77.
Toshiba 40S51U Parts List - PartStore.com
https://www.partstore.com/Model/Toshiba/Toshiba/40S51U.aspx
  1. Cached
  2. Similar
List of Spare Parts for Toshiba 40S51U Parts List. 40S51U UNKNOWN ... Toshiba TV Mounting & Installation. 75024004. SCREW, STAND, MAC000. $0.58.
Toshiba TV Stand for 40S51U Complete with Neck and Screws ' eBay
www.ebay.com > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
TOSHIBA TV STAND FOR 40S51U COMPLETE WITH NECK AND SCREWS in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Parts ' eBay.
Toshiba TV model number 40S51u Google Search
Nov 27, 2016 | Toshiba Televison & Video
Toshiba tv fuse blown
most electronic applications use what is known as a "slow blow" fuse and they are available fro electronic spares shops (JAYCAR and the like ) however if the fuse blows , you have a much bigger problem so take it to a repair shop and have the problem properly diagnosed
Feb 28, 2016 | Toshiba Televison & Video
Sabre tv model # PDP42X32000 D57 AND D58 RED LIGHTS ON AND D45 BLINKING RED. SCREEN IS SHOWING FUZZY PICTURE IN AND OUT
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 19, 2016 | Sabre Televison & Video
Toshiba 37E200U LCD television
T5.0AH 250V used in this TV is a ceramic fuse Time delayed (Slow-Blow) and the dimensions are probably: 5 mm (3/16 in) x 20 mm (3/4 in). You just measure the old one.
Regards GJ
Jun 20, 2014 | Toshiba 37E200U 37 in TV
Toshiba 40rv5252r stand screw size
I called Toshiba for this TV model "40RV525R" and they said the pedestal stand for the t.v. to stand on was an m5, product # 75012791, and the length was approx 20-25 mm
Feb 11, 2012 | Toshiba 40RV525R 40 in. HDTV
Hi i need a picture tube (the blue crt) what all models and sizes of Toshiba fit if i was to go used? It is a toshiba 50h81
You can also use picture tube part number 23008517 which is in model 57H81. Please note that these tubes are no longer available frmo Toshiba.
Dan
Nov 02, 2009 | Toshiba 50H81 50" Rear Projection...
Using multiple card slot
There will be a slot, the size of the SD memory card on the front edge or side of the laptop. The slot will be the same size as the slots in an USB memory card reader.
You can download a manual from the Toshiba WEB site.
You can download any/all the Windows XP or Vista device drivers and manual for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers and manual.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 14, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba MV13L2 13 in. TV/VCR Combo
it should tell you on the board where you took it out of it usually around 125v/4amp
Feb 02, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
Size of a toshiba laptop model
most toshiba a-100 laptops are standard 15.4"
Nov 12, 2007 | Toshiba Satellite A100-S8111TD Notebook
Philips 27PT6441 27" TV Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
