Question about Vacuums
Diablo 926z timer
Red wire, black wire, blue wire. How to connect, I.e. Line, load, neutral
4 Suggested Answers
  • 389 Answers
SOURCE: Hi i got a red green and black wire cable and I
Partial solution. Rob's clarification request is very valid, and you shouldn't mess with electrics if you are not completely sure what you're doing. That said, my guess is that you are in Europe (possibly the UK). Confusion can be caused by relatively recent changes in colour codes, so older and newer wires are coloured differently. Basically, red and brown signify "live", black and blue signify "neutral" and green signifies "earth" (or "ground"). So if you are just joining these cables, red goes to brown, and black goes to blue. But what about the green...?  Some machines are designed to be earthed, others are designed to be not-earthed, and it's not clear to me why you have an earth wire in one cable and not in the other. If the green is in the cable that brings power in to the machine, then it should be fixed to some metal part of the machine It can be FATALLY dangerous if you fail to earth a machine that should be be earthed. I repeat, if you are not absolutely sure what you are doing, don't risk it. Anyway, post more details and it looks like there's at least two of us out here who can help you.
Posted on Mar 05, 2009
wiringlunati
  • 576 Answers
SOURCE: GE on/off timer for a
I would guess that the black wire on the timer is the power in and blue is the power out to the fan (hook it to the black wire going to the fan) The other colors are right.
Posted on Mar 24, 2010
  • 1796 Answers
SOURCE: I purchased a utilitech 7-day
Hi!!
  • The Green wire goes to ground,
  • The White wire is the neutral. (in this case is used to supply power to the clock.)
  • The Black wire will have to be connected to the incoming black hot wire and,
  • The Red wire will go to the black wire going to the light.
In order for the timer to work, you'll need to run a Neutral wire from a nearby outlet into the switch box to power the timer.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Dec 03, 2010
How does the Power Head wire up to the switch on the Rainbow SE?
Here is the wiring for a D4 switch:
Rainbow D3 D4 SE power switch
Rainbow no longer makes the switch with 6 wires, it comes now with only 4.
GoodVac.com
800-775-6586
Jun 29, 2014 | Rainbow 75th Anniversary Canister Vacuum
I need to know how to hook the wires up to the start switch. There are two wires from the external cord and two wires from the internal cord.
white wire to neutral black wire to hot if you post colors I could help you red ,orange, black,pink, blue, or violet are usually hot guessing a striped wire is usually neutral please post colors
Apr 14, 2013 | Dyson DC14 All floors Bagless Upright...
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
I have a Diablo wall switch timer that was manufactured in 1982. It has 926Z on the back. If that is not the model number, I am in trouble. I have lost the operating instructions. Can you help?
Guess we'll just have to give up and throw this away....I've been holding on to one for 30 years, and I remember it being difficult to program anyway....
Jan 16, 2011 | Vacuums
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
LIGHTING QUESTION: I have a GE Pro line T8 Ballast w/ (8) wires (2) Blue, (2) Red, (2) yellow plus Black & White. I know what the Black & White are for and are not connected to the lamps. Can you...
Try this link-- for a wiring diagram--- let us know if this helps-- Mack
http://www.replicasuper.com/wp-content/uploads/2016/01/T12-Ballast-Wiring-Diagram-Here-Is-An-Example-Of-A-Circuit-That-You-Can-Make-The-Guidelines-For-Making.jpg
Oct 27, 2017 | Vacuums
GE on/off timer for a bathroom fan - switch has four wires Green - ground White - neutral Black - power Blue - lead My fan has two - white neutral and black lead I have tried...
Mar 23, 2010 | Vacuums
Mar 05, 2009 | Electrolux Epic 6500 Vacuum
Connecting motor part
Hi Charlotte,  Yes, colour coding of wires is a nightmare, isn't it!? Red and brown both signify "live", and blue and black both signify "neutral".  So you should connect brown to red, and black to blue. I hope this is helpful. If you need more guidance, please post here again and I'll see what more I can do for you. I value your feedback, so please remember to rate my response. Good luck!
Mar 04, 2009 | Dyson DC08 Cylinder Bagless Canister...
Vacuums Logo
135 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
