Question about Dewalt Heavy - Duty 10" Wet Tile Saw - D24000
Superiorbuilt wet saw cuts crooked because bearings on table are gone..does anyone know where i can get parts for it
Table has too much play to run tile straight ...also with a square lining up table with blade only front part of blade hits and the back of blade runs towards the right...can't seem to alien total side of blade to square
2 Suggested Answers
  • 10865 Answers
SOURCE: crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Posted on Jan 28, 2009
Bosch4100saw motor trouble
Hi. It could be a weak field. Or the rear bearing (or front one) on the armature is seizing or gone. If you remove the back part of the motor housing you can see the rear portion of the armature - look for a black burnt area around the perimeter. Regards.
Sep 09, 2013 | Bosch 4100 09 10" Worksite Table Saw...
My jet table saw has excessive vibration.
Sounds to me like the arbor bearings have too much play, or one of them has failed. With the saw unplugged, see how much play there is in the blade by pushing it side to side and up and down. Remove the blade and grab the arbor with your hand and see if you can move it any direction. You should have virtually zero play. If that is the problem, major disassembly is required. If you have a pair of reasonably precise calipers and you get the bearing removed, there are several bearing distributors with good websites to find replacements pretty cheap. If only one bearing is bad you should replace both anyway. Good luck!
Nov 17, 2012 | Jet 708315LSB 10" Benchtop Tablesaw with...
D24000 wet tile saw smells of burning. What could this be?
mmm.. motor problem,armature or field coil burned or bearing burn motor housing
Jun 03, 2012 | Dewalt D24000S Heavy-Duty 10-inch Wet Tile...
Nut that holds the blade loosens after one cut. saw also runs loud and rough. believe is it related to the "gears" and cause of the nut loosening.
Sounds like a bearing is shot and rattling up the works there. Rock the blade back and forth and see if there is any play in it, check the bearing at the other end of the shaft. Is this one of those skil saw motor saws? Or is the motor hanging down below the blade? Need to know that before I can tell you what it is.
Mar 14, 2010 | Craftsman 10" Table Saw
I have an old craftsman table saw. i believe the "brake" or gears a shot. the saw runs very loud and shakes. now no matter how much i tighten the blade the nut loosens after one cut.
With the saw unplugged and the blade tightened, using your fingers try to wiggle the blade side to side and lift it up and down. Other than a little flexing of the blade, there should be no movement. If you have much movement you have a problem and the saw is dangerous. If this is a belt-driven saw, then you may be able to replace the bearings on the arbor (the shaft the saw mounts to) or you may have to replace the whole arbor. If this is a direct-drive saw (the saw mounts directly on the motor shaft) then the bearings that have failed are in the motor and you are less likely to be able find and install replacement bearings. If you find the model number of your saw, you might be able to find drawings and replacement parts on this site:
http://www.searspartsdirect.com/
Thanks for using FixYa. Let me know if I can help more. Good luck. Al K
I have a 10'' table saw
If it cuts straight it's fine. It's likely just some play in the bearings. I wouldn't worry about it unless it starts to cut not so straight...
Oct 06, 2009 | Craftsman 10" Table Saw
Cut is always crooked. From the top to the bottom of the cut is always crooked. Can not get the saw to cut a 90 degree ( or even close to 90) angle. Even of I adjust the table to be out of square to the...
It sounds as though you may be cutting too quickly. Try decreasing the pressure you are applying to the wood.
You could also try tightening the blade more, until it PINGS when you flick it with your finger.(When it's stationary of course)
I'm assuming your guides are adjusted correctly.
JR
Sep 27, 2009 | Ryobi 9 in. Benchtop Band Saw
My Husky tile saw starts to cut straight and ends up crooked, have tried to adjust tray and still ends up crooked??????
Make sure both sides of blade are wet. Make sure blade is not worn out. Do not feed the tile excessively fast.
Next, and very important is that the blade arbor is at true to the table. If the saw is slanted in the least, the saw will track off course. I am talking VERTICAL slant.
Verify that the arbor bearings are tight and there is no "end shake"
Sep 22, 2009 | Wet International Husky 7" Wet Tile Saw...
Wet saw not cutting material completely
It might need a new blade. But try putting an old tile or offcut behind the tile you are cutting. Make sure the table surface is clean and flat. Residue tends to build up around the front of the blade which could cause the tile to crack. The ryobi's have a habit of water getting into the motor and the bearing destroys itself. Next time you take the blade off, take of the blade support and put bearing grease behind the rubber washer. I've blown up two this year until I worked out what the problem was.
Apr 25, 2009 | Saws
Crooked cuts
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Dewalt Heavy - Duty 10" Wet Tile Saw - D24000 Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
