Question about Plumbing
Belanger shower faucet model 4112CP
Newly installed and no water coming out
  • 68 Answers
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
I have a single handle belanger shower faucet- replaced cartridge and no hot water , Need help
Check the hot water shut off valve, when the washer fails sometimes the valve itself sticks closed, and sometimes the washer breaks up and clogs water passageways down stream...
To test, pull the hose off of the hot water shut off valve, open the valve and see if you have water flow. (route hose into a bucket, you need more that a small amount of water.....
If you have good water flow from the shut off valve, then you likely have a particle that has lodged in the passageways of the faucet. Reverse flow with air pressure and see what you get out....
Jul 17, 2011 | Plumbing
I have a newly installed shower with moen chateau shower faucet. After several successful showers, the water has completely stopped. what could be wrong?
There is probably junk in the lines that has clogged mixing valve Moen is pretty simple to operate and maintain, however, before the new system was installed, maybe it was done, the water should have been run through the valve itself, without mixing valve installed. I am going to provide you with a video that shows how to remove the valve and, with a little help, you can remove valve and hopefully can clear the lines by running water, slowly, through the fixture, without the valve installed. You would want to try this anyway to make sure you have flow to the faucet:
http://www.youtube.com/watch?v=J-SNBNijfQc
Make sure all junk is cleared from lines and re-install your valve. If your cold and hot water is backwards, remove the valve and rotate 180 deg. and re-install. You can note the way the tabs are when you remove, and install in the same position.
May 30, 2011 | Moen & One Handle Tub & Shower Faucet
Rusty water comes out of cold water faucet
Rust is usually a sign of galvanized pipe mixed with copper pipe incorrectly.Could be the pipe nipple used for the tub spout connection to the valve.You could change it to a brass nipple might be the problem
Jun 24, 2010 | Moen 1 Handle Lever Shower Faucet With...
Remove belanger one handles shower faucet cartrige . I took off the little colouted rubber plug but I cannot seeinside to remove the small screw to get at it. Can't even see what kind of screwdiver that it...
Please contact Bélanger Customer Service at 1-800-361-5960 with your product number or view our website at www.belanger-upt.com to find your model number.
Nov 07, 2009 | Plumbing
Faucet issue
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Just installed shower and faucet in bath tub when you turn the water on the water comes out of the faucet and shower head. When you pull the lever for just the shower the water cuts off at faucet and comes...
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Mar 01, 2009 | Plumbing
Plumbing Logo
43 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
