Question about Vivitar ViviCam 5100 Digital Camera
Camera has a black looking on screen when i turn it on. will not do anything
  • 797 Answers
Try to get any menus with out the camera plugged into the PC or any card inserted.
Will it get a menu?
If you still have NO MENU and Nothing on the screen, the problems deepen.
Possibly a defective or broken LCD.
If any of the lites turn on when you turn on the camera and no LCD shows, you may have a bad LCD.
Appears to need some kind of repair.
Here is a link for further info.
Go to:
http://vivitar.com/en-us/Support.aspx
Ask for your model.
Posted on Sep 29, 2008
Camera won't show anything but black in the screen ... Or looking through the eye piece (canon S3 power shot) think the cold weather caused it
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 14, 2010 | Canon PowerShot S2 IS Digital Camera
The screen is black, i cannot see anything on the
First thing to check is to make sure that you didn't just accidentally press the DISP or DISPLAY button on the back of your camera, manually turning the screen off. Press the DISP button once with the camera turned on. If that didn't correct the problem, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 10, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera's screen is black, but still takes pictures.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, try pressing the DISP button once with the camera turned on.
Dec 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Jul 13, 2009 | Olympus FE-230 Digital Camera
Black screen
you need to change the lcd screen but this is quite costly for a repair, better yet change the camera
Jun 16, 2009 | Polaroid i737 Digital Camera
Pentax optio S50 Digital Camera problems.
does anything on the screen change when you press the display button? will the lens open? have you tried taking photos without the memory card in the camera?
Apr 12, 2008 | Pentax Optio S Digital Camera
Black screen
If the camera is taking photos that are pitch black, and you cannot se anything, then it could be one of two things. 1) your backlight AND lcd are damaged/detached (if it was white that would mean the backlight is working) or 2) the CCD (like film for a digital camera) is damaged. If you can see an image, but it is VERY dark, then that would indicate a backlight error. There are 2 ways to test this. 1) take a picture and transfer it to your computer. If you can see the photo you took on your computer then it is a backlight/lcd problem. or 2) under the rubber where you usually plug the usb in, there may also be a plug that looks like it would fit a headphone jack. There should also be a cable with red/white/yellow on one end and a headphone looking plug on the other end, that came with the camera. You could connect this to your camera and to a tv and you should be able to then see what the camera sees. If you can then it is a backlight/lcd error. If you can't see anything, make sure the tv is on the right setting and that the yellow plug is fully inserted. If you still can't see anything then it is probably a ccd error, in which case you should contact sony.
Jan 29, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Image blacked out on LCD and can not see image in view finder
Try connecting it to a computer and then turning on the camera. For some reason that fixed it for mine.
Nov 24, 2007 | Canon PowerShot SD10 / IXUS I Digital...
Lcd monitor screen stays black
there may have been some kind of damage to the lcd. sounds like you are going to have to send it in to have it fixed.
Jun 13, 2006 | Casio Exilim EX-S500 Digital Camera
Vivitar ViviCam 5100 Digital Camera Logo
44 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
