Question about Homedics Humidifiers
My Homedics UHE-CM45 Ultrasonic Humidifier, Cool Mist is leaking
My ultrasonic humidifier is leaking
3 Suggested Answers
  • 7 Answers
SOURCE: Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
Posted on Feb 12, 2008
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
Humidifier is leaking where the top meets the base. How can I fix this?
The humidifier may be reacting to being overfilled. A little less water fill may cure the problem.
Jan 06, 2016 | Air Innovations Clean Mist Ultrasonic...
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Motor runs but no mist comes out on EV-HD15
If there is water in it, it sounds like the ultrasonic unit failed.
Dec 05, 2014 | Sharper Image EV-HD15 Cool Mist Ultrasonic...
My homedic s humidifier is leaking.I turn it on in the evening and next morning I see it in a puddle of water.Happens every time.
Chances are it is just condensation not leakage if it's only wet when its running. Nothing you can do except put a towel under it.
Dec 01, 2014 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
There is not mist coming out. What should I do??
The moisture released by this (or any ultrasonic) humidifier should not be visible, so it is very possible that it is working correctly. Try filling the reservoir and marking the water level with a small piece of tape. Then run the humidifier for a few hours, and check the water level again. If the water level is below the edge of the tape, then you know it is releasing moisture into the air, and everything is working fine.
The older style of humidifiers created a mist by spinning a disk that was partly dipped into the water reservoir. They had to be refilled often, and the mist could leave water spots or dust on nearby furniture. The water level should change very slowly in your ultrasonic humidIfier compared to a misting humidifier.
Jan 13, 2011 | Vicks Ultrasonic V5100 Humidifier
Sunbeam Ultrasonic Humidifier SUL495 quit working in first week. What may have happened.
Same problem. It worked for about a week, then gradually stopped producing mist. No solution.
Nov 29, 2010 | Sunbeam Ultrasonic Humidifier
Humidifiers Logo
624 people viewed this question
Top Homedics Humidifiers Experts
Mack Baxter
Dennis
Are you a Homedics Humidifier Expert? Answer questions, earn points and help others
