Question about LG DLG5932W Gas Dryer
How to check dryer thermistor
Hello, I have a LG DLG5932W dryer that is not drying very well. I have checked the continuity on the thermostats, ignitor and sensor assembly, all check out okay. Tried to do diagnostics by pressing the more time, less time and power button simultaneously, as described in service manual. Thought I might get a thermistor error code. I got all lights and a 1920 code. Don't know what that means. Does that me something and is there a test for the thermistor?
2 Suggested Answers
  • 489 Answers
SOURCE: lg 8377 no heat,dryer runs
You may have a high limit switch that has failed. You will need to tear down the dryer to get access to the heating element. Look for the heating element on the bottom right side. There are 2 thermo discs located on the left side of the heating element. Test both of them. If there is no continuity, change that part.
Hope this helps.
Posted on Aug 28, 2011
My LG TROMM DLG2526W dryer is not heating.
Check thermistors. Two in heating chamber and one or two in fan housing. Clean surfaces and check for continuity.
Aug 17, 2017 | LG DLG5932W Gas Dryer
I have a LG DLE 2514 electric dryer and it just isn't very warm. The sensor dry has never really worked. Other wise it runs fine. I usually just have to dry my loads twice. Is there any way to...
Hi utke...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Sep 05, 2011 | LG DLE2514 Electric Dryer
My dryer only has heat for 2 min after it starts then the flame goes off
Hello
Does the problem happen in timed drying as well as automatic drying?If it happens in all modes I would suspect a high limit thermostat is tripping. Especially if it starts back up after cooling down.
Check for clogged or obstructed vent hose .Make sure your getting good air flow from blower to the outside.If you have flexible hose make sure there is no water collected in it.Make sure lint screen is clean.It may be time to take off back panel and check for massive dust deposits.If ok ,then with the back is off you can put a volt meter on timer side of thermostat or stats and turn on dryer . When flame cuts out at 2 minutes ,see what volt meter says .If voltage good there then the problem is high limit thermostat or bad igniter or bad gas valve.If no voltage then then the problem is with moisture sensor.
Beware of HIGH VOLTAGE
Hpoe this helps
Aug 05, 2011 | LG DLG5932W Gas Dryer
Not drying, actually weton door and drum inside when drying towels
Hi tgfritz204...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Jul 30, 2011 | LG DLE2514 Electric Dryer
I have a LG-DLG5932W dryer and can't find the reset switch. The sensor on the dry was triggered (no heat) due to air duct clogged. Had the air duct serviced and now to rest the switch. Please show me a...
Welcome to FixYa.
While I don't have a video or diagram I can tell you on the LG dryers there is indeed a "reset" for the heating/burner funnel (as you obviously know) on the right hand side of the funnel, however they also incorporate a no reset "hi-limit thermostat" on the left side of the funnel. Once it is tripped it must be replaced. This is only present on the gas dryers.
It is located on the left side as I mentioned, but the other is on the right side of the heater housing/burner funnel and will resemble the images shown below. It is part number 6931EL3004B ( the reset type is part # 6931EL3003C ) and available at "searspartsdirect" (which also has a illustration which may help you) or "repairclinic.com" to name a couple.
i.e. NON-RESET
i.e. RESETTABLE
With the aid of an ohm meter you can check the non-reset for continuity, the other you should be able to push the center reset button ( listen closely for a "click" ) but it too can be ohmed out for continuity to confirm or dismiss it's condition.
Hope that help`s move you forward. If so please take a second and rate the guidance and a testimony to the assistance you received here at FixYa, either or all is appreciated.
Let me know if you can provide any further info and I'll continue to help in any manner I can. Good luck
Regards,
Macmarkus :)
Apr 03, 2011 | LG DLG5932W Gas Dryer
Dryer not drying model is LG DLE2516W
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Dec 31, 2010 | LG Dryers
Lg dryer wont dry
Check your Wiring
For video and pictures on how to replace the element go to the following website:
Dec 10, 2010 | LG DLE2512W Electric Dryer
I have a LG Tromm DLE 3733S dryer. I have power to the dryer, however, it is not drying the clothes. The clothes continue to be wet after 2 drying cycles. Please help! I have children that need clean...
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
For further instructions on how to replace the element go to the following website:
Oct 03, 2010 | LG Dryers
DLG5932 gas dryer blows its overheat fuse, after reset by technician it heated fine. On the first load of laundry it heated for a while, and then blew out the overheat fuse again. Dryer was totally cleaned...
The dryer is overheating but is not the fault of the vent. Have the technician check the operating thermistor on the exhaust behind the blower wheel. This thermistor acts as the thermostat for this dryer and if it is off will either not allow the dryer to heat or will overheat the dryer like in your case and cause the thermal fuse to blow out or trip. He should measure ohms and according to temperature and should have access to what it should measure. If the thermistor measures bad, replace thermistor. If this measures good the control board is reading the thermistor wrong and the board will need to be replaced.
Thank you
Jan 22, 2010 | LG DLG5932W Gas Dryer
LG DLG5932W Gas Dryer Logo
26 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
