Question about Bosch Nexxt 500 Plus WFMC5301UC
WFMC5440UC ERROR CODE E17 - Bosch Nexxt 500 Plus WFMC5301UC
2 Suggested Answers
SOURCE: e17 error code
Got an E17 Error today on a Bosch 6450 Series washer (the user manual says Bosch Vision 300/500/DLX series). Here's what I did to fix the problem.
- Tilted the unit back, propped up the front with some 2x4 (lying flat; that's all the room I had).
- removed 3 screws (Torx 20 I think) under the front lip. Then slid the cover (below the washer opening) down. This revealed the pump to empty the washer, a manual door lock opening pull rod, and a drain line (?)
- Looking through some holes in the front panel I saw some water on the bottom of the washer... but I spent a lot of time with the pump cleaning it out first (some zipper pull got in there and made a lot of plastic shavings). - Ultimately I got my hand the bottom of the washer and soaked up the water that I could find. That's when I realized
- there is a micro switch mechanism at the bottom near the front. This must be the "AquaStop". The mechanism contains a bit of styrofoam that floats up on any little amount of water that collects under it and triggers the microswitch. So, I removed that unit, wiped the water up... put it all back together. No more E:17 error.
Still don't know how the water got there in the first place though.
Posted on Jan 01, 2012
Hi we have a Bosch Exxcel 7 with E17 error code. We've checked filter and pressure. Any ideas??
E17 indicates that water is leaking and getting into the bottom of your machine
Feb 23, 2017 | Bosch Washing Machines
How do your error E17 on a Bosch Maxx 7 varioperfect.
Hi Kerry, The same question was asked on this site back in March 2009 !! and the link below has an answer..... CHEERS..
E17 error code Fixya
Apr 04, 2016 | Bosch Washing Machines
Model EI36EC45KB. What does flashing code E17 indicate?
think I would call the place I bought it and request a serviceman come out .
Sep 29, 2015 | Electrolux Cooktops
I have a bosch lifestyle dishwasher that keeps coming up e17...we have had plumbers around and there is no problem with pipes or water so what else can it be
You did not specify the model so I can only assume what means the alarm code E17 - probably water level too high - flow sensor.
The dishwasher has, for some reason detected an overfill and is reporting that through this error code. The flow sensor note is there as that can cause this fault code to be displayed.
Dado
Jul 10, 2015 | Bosch Dishwashers
How to reset canon pixma error code e17
canon gives great support for everything. Pixma error codes can be found ere: PIXMA Printer Error Codes and Error Messages
and even on Fixya this was answered here: When go to print message pops that there is paper jam when in fact there...
Feb 20, 2015 | Canon Office Equipment & Supplies
How to fix error E17 code on eziset 9.5 kg top loader
Supply problem.
Check to see if water hose is plugged and test water pressure.Check water valve supply shut off.
See if filter is plugged.
Run full cycle w/no clothes in washer. Add 1 cup of vinegar,no soap.
May 03, 2014 | Washing Machines
I just bought my washer today and it won't finish the first cycle. It is showing "E17" and won't drain. What does "E17" mean and how can i fix my washer. Help!!
When the washer shows error code E17 you need to turn the tap fully on and check that the supply hose is not bent or jammed up, next make sure the filter is clean. Then make sure the water pressure is not too low. After you do all that, run a load with no clothes in the washer and use one cup of white vinegar and the code will dissappear
Nov 19, 2009 | Bosch Washing Machines
Bosch Nexxt 500 Plus WFMC5301UC Logo
26 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
