Question about Refrigerators
Trimark pop up t handle
Can't on lock, it will not pop up!
    Master:
  • 560 Answers
Try restting the breaker controlling the oven.
Posted on Nov 22, 2013
I have a motorhome with a trimark handle model
The latch to be removed by taking off the inside plate. there should be a couple phillips screws on the inside. the handle should come off with the plate exposing the latch so it can be turned with a screw driver to open the door and replace the latch.
Sep 10, 2014 | RVs
Nissan versa plastic door handle lock cover popped off
Look for clips, screws, brackets,etc,and try get all in place, the covers can fit in a specific way.
Apply some glue to hold it in place, providing that the cover fits perfectly, if needed to visit the mechanic or bodyshop.
Jan 24, 2014 | 2009 Nissan Versa Hatchback
Door handle broke, can't open door from inside but still from outside
the inside door handle railings probably popped off, its a long bent to shape piece of metal running from the handle to the switch, you will need to take the inside door card off using a screw driver and popping the clips out, peel back the plastic cover enough for you to see, use a torch to see where it has popped off and clip it back in, if you try using the handle and you can hear the metal rod moving around it mights still be attached but the retainer clip has jumped off clip it back in. should solve your problem, if its all still in tact check to see if the child lock feature is working properly and isnt stuck to the lock mode. cheers hope it helps :)
Jun 22, 2010 | 1995 Buick Century
I need to print out a discription of how to replace a door handle
First, remove the window switch/door lock switches from the door panel, these are usually just clipped in, sometimes held in by a screw. Then, remove the outer cover for the interior door handle. This has one screw in it that you should be able to see (or see the little panel covering it which needs to be popped off first- be careful not to break it!). The plastic piece can then be slid slightly forward and popped out. Check to see if you have a speaker in your door. If so, you may have to pop off the plastic panel covering it, and unscrew the speaker, then disconnect the electrical connectors and take it out of the way. There should be two screws, if memory serves, underneath the grab handle of the door, and then just check the perimeter of the door panel to make sure there are no other existing screws in it. After all of the screws have been removed, you can then begin at the bottom and (carefully) pop the door panel out of its clips. Once the bottom and sides are popped out, pull up slightly to pull the entire panel up and off of the window sill. Now you can get to the actual door handle. Unbolt it, and disconnect the little clip/clips behind it which hold the metal bars in place. These bars are what pushes and pulls on the actual latch and lock assembly. Be sure not to break the clips! You may need to reuse them. The new handle can then be clipped back in, and then bolted back up. Important: Test out the function of the new handle before reinstalling the door panel and all of the accessories. If you have a problem, it will be much easier to fix or troubleshoot with the door panel already off! Make sure you dont lock yourself out of the car, in case the door handle fails. Once satisfied that the handle is working properly, install the door panel by hanging it on the window sill first, then lining up the clips and snapping them back in, this usually works best with a little smack of the palm against the door panel. If a clip will not go in, check to make sure it is properly installed and lined up. Once the door panel is fully lined up, screw in the two screws located underneath the arm rest/grab handle, and any other screws you may have removed. Install the speaker (if youve removed it) along with its plastic cover. Pop in the plastic covering for the interior door handle, and screw that in as well. Pop the plastic covering back on that. Now, reconnect and pop the window switch/door lock switches back in, and you should be good to go!
Nov 13, 2009 | 1998 Toyota Camry
How do you remove window crank handle
There's a special tool designed to release the lock ring behind the crank. The tool slips in between the door and crank and releases it. You could also use two metal objects to push on both ends of the opening to pop the pin out. This pin will go flying when it pops off. You can also take an old terry cloth towel and slip the hemmed or finished edge between the crank handle and the door and slide it back and forth with an upward pressure. The towel will catch on the points of the locking ring and pop it right off.
Oct 30, 2009 | 1995 Pontiac Sunfire
How to change it myself
get a manual from the library or parts store; usually a couple of nuts on the inside of the handle. Doable but frustrating.
May 30, 2009 | 1994 Toyota Corolla
Front door panel removal
There is a triangular piece, at top corner, covering a screw behind the mirror. Remove that screw. Remove the piece that covers the handle and remove the screw holding the handle to the door. Look through, where door handle was and remove another screw just above where the handle was. This screw is holding the panel to the actual door. Pop the cover off for the automatic door locks and disconnect them. Lift the panel in an upward direction.
Nov 11, 2008 | 2000 Ford Expedition
Door handle loud pop- won't open front driver door
hi yes there is a plastic clip that holds the the door handle rod to the handle and connects to the lock you should be able once the pad is off take the bolts out of the door lock it will drop down so far as you can get at the door handles retaining bolts and the clip itshelf you should be able to replace the clip without taking the handle out bit fiddley but not that difficult yates210456
Jun 27, 2008 | 1999 Honda Accord
Door handle broke
.with a little luck you can try jiggling it for a while youmight get it ot pop open, if not youll needs to remove it from under counter. its held under countertop by 2 phillips screws (dropping the adjustmendt legs under unit will give you additional clearance to acess the screw head. after sliding d/w foward only 3 or three inches you gain acesss to the strike plate thats locking your latch. youll need to replace door latch and/or handle.
Feb 24, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
