Question about Sharp PG-MB66x Projector
Sharp mb66x projector doesn't turn on
The only things that 'works' is the standby led that glows red. replaced batteries in remote and that has no effect on the projector either
SOURCE: SHARP XR-1S won't turn on
OK - I've fixed mine (so it looks) - loads of dust inside unit seemed to caused the problem - vacuuming vents (as the manual prescribes) just shifts all the dust inside around and obviously causes some disruption.. solution - remove 4 screws underneath and lift off top (carefully) remove side panel screws (where Av inputs are) again carefully. Now go around each vent at the front, side and underneath and give areal good blow in each a few times. Plumes of dust and rubbish fly out - keep going until it's all clear. Reassemble and fingers crossed. Mine then started up and didn't turn off - there's a horrible burning smell (dust settling near lamp I presume) which is now fading. Been working 30 mins now with no trouble!
Hope it works for you - will post another update if I have any further problems - no news is good news!
Grahamkida
Posted on Oct 04, 2008
SOURCE: Sharp Xg-50X projector won't turn on. Replacement light not on.
I pulled the projection bulb and did a continuity check on the filiment. It was open. I ordered a new bulb.
Thanks.
Posted on Feb 14, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Posted on Jul 23, 2009
projdoc
  • 2237 Answers
SOURCE: SHARP XG-P25X PROJECTOR PROJECTOR RUNNING
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
Posted on Aug 04, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp XR-10X projector. Makes a loud whirring
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Jan 18, 2010
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Digital projector not working
check if standby led on projector is glowig red, if yes pannel keys may be in off mode, try to power on with remote control.if standby led does not glow, check power cable and its connections and safety fuse inside projector.
Aug 14, 2010 | Sony VPL-ES1 Multimedia Projector
Jul 06, 2009 | Sharp XR-1S Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Cannot unlock keystoke on PG MB66X
just press keystone key on remote & then adjust the kwystone + or - .to do so u need to feed a input to he jector!
Feb 23, 2009 | Sharp Notevision PG-B10S Multimedia...
Sharp PG-MB66x Projector Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
