Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi WT-46809 Need help with 2-1 code
I hooked up the DTV mode good picture but no sound ? Help please
Posted on Aug 22, 2008
6ya staff
SOURCE:
Vista Electronics
  • 1694 Answers
SOURCE: MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Posted on Oct 11, 2007
Anonymous
SOURCE: how to price a Mitsubishi WT-46809 HDTV
I sold mine (bought late 2000) for $450 easy.
Posted on Jan 09, 2008
Anonymous
SOURCE: my mitsubishi wt 46809 will not stay on.Iturn it
put it out on the curb and go buy an american tv!
Posted on Feb 08, 2010
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: I have a Mitsubishi wt 46809 with a error code of
That is error code 22 which means the unit had a momentary recovery from a reset. You should unplug it for 30 minutes, then plug in and try it again. This will reset the fault and if there are no other problems the unit will work ok. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 07, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: on my mitsubishi wt-46809 the
it is short protection and means one of the fuses for the convergence circuit is blown.
I can help with this if you want.
SD TECH
Posted on Jan 14, 2011
On my mitsubishi wt-46809 the error code is 2 blinks pause 2 blinks. What is this?
SD TECH
Jan 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
I have a Mitsubishi wt 46809 with a error code of flash flash pause flash flash
hardrocko
May 07, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Powers Off; Code 2-2
The 2 fuses you mentioned are associated with the convergence IC. If they are open then the convergence IC is either bad or you have a "cold" solder joint on the IC.
Feb 01, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
electech
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 rear projection
see if the ics warm up ...out your hand on them if so they getting power.. if cold you lost a resistor or 2.
Sep 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT 46809
22 is a error code for a short protect which is triggering shutdown . Try unplugging the crt circuit boards and seeing if the fuses still blow when you press power.
Jun 22, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Wt-46809 Not coming on
Try hard reset==leave unplugged from AC a while.
Next--NMI==need more information!
Is this your first problem? Any symptoms before shutdown?
Oct 09, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
