Question about Audio Technica Artist Series ATM350 Professional Microphone
Need a wiring diagram to replace broken TA3F connector
The TA3F connector was shattered, and I need to replace it. There's a white wire with thicker insulation, and then a small red twisted pair and a small yellow twisted pair. I'm assuming the white is ground, red is hot, and yellow is cold, but I can't find the wiring diagram anywhere.
5 Suggested Answers
  • 5603 Answers
SOURCE: need the wiring diagram for a audio-technica
I believe on the 4 pin connector of the pack, pin 1 is shield/ground and pin 2 is low impedance input. One of the other pins is bias voltage and the other is high impedance.
In the UNIT I had, there was a connection diagram someplace in the battery compartment, either on the cover or the case. As I recall it had poor conrast to read and find it so check closely.
Posted on Sep 30, 2009
  • 417 Answers
SOURCE: Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Posted on Apr 15, 2010
criss_michae
  • 63 Answers
SOURCE: Need an internal wiring diagram (schematic) for an
After running a search online through 3 search engines, I cannot find a schematic for that microphone anywhere. Your best bet is to look and see if you can find something missing (a spot that's supposed to have a wire that doesn't). I'm going to have to apologize, but it's all trial and error at this point.
Sorry.
Posted on Feb 11, 2011
alpug
  • 1961 Answers
SOURCE: the mic plug came out
hi click this link to have the diagram for the audio technica microphone connection
http://www.4audio.at/rcms/upload/2_100_100_AT-wiring_diagram_web.pdf?PHPSESSID=892efd3062a0b424feb0a8d0157520b9
read more here
Thank you for using fixya..
Posted on Jul 04, 2011
Try replacing the horn and found a broken wire now do i do now 98 ford explorer xlt
Just buy a wire connector for that size wire and reconnect the broken wire. Wire sizes vary by uses with the lower numbers being thicker wires. I would guess the wires you have are around a 14 gauge or a 12. You will need a connector that has that diameter to allow a proper fit. There are connectors which crimp together. The more modern screw together.
Apr 20, 2013 | 1998 Ford Explorer
2001 Cadillac Deville oxygen sensor wiring diagram
The wiring diagram shows the wiring color code, Power rating and connector plug used. The wiring diagram explains the vehicle's electrical connections with color code. It's a bit complicated to understand.
Apr 07, 2013 | 2001 Cadillac DeVille
88 Coachman p37 rv. need wiring diagram. Does battery post on alternator come direct from battery? plug in has red wire. red wire with black stripe and brown wire. Where do they run to wire diagram wise?...
The solenoid is most probably for your starter ( just like an older car), what type of Coachman is this? p37 as a model doesn't come up.
Nov 30, 2017 | RVs
Need the wiring diagram for a realistic eq booster model no. 12-1955
The main colors are:
Green - L+
White - L -
Brown - R+
Gray - R-
There are 3 sets of these. The ones with thinner wire are for high level input (from a stereo's speaker outputs). The two other thick sets are the speaker outputs to front and rear. They should've been attached to connectors labeled front and rear, if they aren't, you gotta find out through trial and error with the fader. Lastly, black is for ground of course, then the thin red wire is for 12V+ power (on with ignition), and the thicker red wire is power output to a deck, if you want it to turn on along with the amp/eq.
Apr 16, 2011 | Car Audio & Video
I took the wires of the thermostat and heating coil and cannot remember how they go back on. I need a wiring diagram to put them back on properly
if you look at the connectors the wires that connect to the heater are larger and the wire is thicker,it doesn't matter what wire goes where on them,also the heater wires should be red and the other is red with a white stripe and like i said it doesn't matter what post on the heating element the wire with the stripe or the solid red wire connects to.the same with the thermostat
May 31, 2010 | Dryers
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Shattered side stand safetly switch 2008 BMW Adventure
Take the 2 wires and connect them together. Either by a **** connector or twisting them together and electrical taping them in place.
Jun 30, 2009 | 2008 BMW F 800 GS
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
Jan 09, 2008 | Maytag MFI2568AE Side by Side French Door...
Audio Technica Artist Series  ATM350 Professional Microphone Logo
37 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
