I have a problem sending my colleagues files from office 2007 since they still have 2003. How do I convert the files in word or excel before I email it to them?
This is becoming a big problem for me since I have to send my excel reports every week
nao consigo instalar o Word em meu notbook com vista home premium obrigado pela atencao
Same Problem
Apr 20, 2009
-   I have a problem sending files to my classmates from office 2007 since they still have 2003.how do i convert the word files to 2003 before emailing to them?-   sugand
Mar 24, 2009
-   PRODUCT KEY OF MS OFFICE 2007-   Guest
Mar 08, 2009
-   linces kye no free ms office 2007-   ashish_aman4
Mar 02, 2009
-   Office 2007 not working properly need to get free download-   ashoksinha12
Jan 24, 2009
-   I NEED TO FIND OUT HOW TO GET A POWER POINT 2003-   MZBASKETBALL
i have a complete solution about this problem a very small solution but for this either send me mail on my Email- Id vohrasourabh@gmail.com or you can also call me at any time at +91-9873247199(m)
You can save the Office 2007 files in a format that is readable by previous versions of Office.
To save a file in compatibility format, follow the following steps:
1. Click on the Office Button (Round office button on the top left corner)
2. Go to "Save As" option
3. On the "Save As" option, select the "...... 97-2003.." option
4. Specify a filename and save the file at the desired location
This file can be seen by others using earlier version of Office. Please note that their are some enhancement features of Office 2007 which may not be visible to people who use older version of Office.
While saving the file go to office button Click of Save As --> Excel/Word/Powerpoint 97 - 2003 Formats.
It will open the file In all the versions from 1997 to 2007.
Hope your Problem is solved.
Further contact me in case you have any problem in Micorosoft Office.
We have a big trobo Microsoft office 2007 and outlook
Stop working, and stop may printer, I dont think they have a right to stop our job.
What to do with this?I prefer Microsoft word, or Pad word. but the Pad word go to Office 2007. is hard. Naw I need to Printer and I am not get solution. Lexmark 2600 series. Make copyes. nothen more.
Have some sugestion.
It is possible to save office documents from 2007 to a 2003 compatible format. When ready to save your document, click 'Save As' from the File menu, and then choose the option 'Office 97-2003 document' and give the file a name as you normally would. This will allow users of earlier versions of Microsoft Office to read these files.
If you have any further issues please contact me for assistance.
simply download the Microsoft Office Compatibility Pack for Word, Excel and PowerPoint 2007 at Microsoft website. http://office.microsoft.com/en-us/word/HA100444731033.aspx may be this link is used to solve u r problem.
Here is the easiest solution - Choose to save the document in the older file format. For example, when you want to save a word 2007 document, click the big office button in the upper left corner, select "save as", then select "word 97-2003 document"
It is pretty much the same in the other office 2007 apps as well.
Also, there is a "compatibility pack" that can be installed for users of older office versions. So if your colleagues have office 2003, they can install the "compatibility pack" and it will allow them to open the newer file formats. It takes some effort on your colleagues part, but it is probably worth if if they don't plan on upgrading anytime soon.
when I try to use mail merge in 2007, and complete the merge, it only pulls in the first three and...
(More)
when I try to use mail merge in 2007, and complete the merge, it only pulls in the first three and last three records form my chosen database file. All files are the same so I believe that it is not the database and that it is the template doc in word. can you advise.. I did try to repair word 2007 by re-installing, but that did not work... possibly I have a conflict with another program installed....
I tried to unstall the existing office 2007 which is not functioning well at all especially Word repeatedly has problems and very slow.
So I tried to unstall the existing 2007office and tried to instal my disc with office 2003.
But I found the office 2007 does not uninstal. only after this I can try to unstal my earlier version of office 2003 with me.
What to do on this? any suggestion please.?
N.Ramabhadran
I have the same problem of sending my files from office 2007 since most of them still have 2003. How do I convert the files in word or excel before I email it to them?
raj_20001@hotmail.com
Comment by Guest, posted on Apr 12, 2008
Converting of MS Office 2007 files to MS Office 2003
Comment by Guest, posted on Mar 23, 2008
i m having problems in sending my friends the word document..they dont have word 2007 and hence they are not able to read the files i m sending them
I am unable to share Power Point Presentations because they need to be converted to office 2003 files. I tried to save as type but it didn't seem to work.
