Question about AMDM Intelliseat - The Ultimate Bidet Electronic Toilet Seat
Intelliseat light keep flashing and dose not work
  • Anonymous Feb 18, 2016
    If you need a replacement parts or a new remote you can find them herehttp://www.ebay.com/sch/i.html?_from=R40...
Im looking for intelliseat toilet temperature sensor
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat, Bidet Seats ...
https://www.amazon.ca/IntelliSeat-Ultimate-Bidet-Electronic-Toilet/dp/B0050EJBQ0
  1. Cached
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat in Bidet Seats. ... Bio Bidet BB-i3000 Premium Dual Temperature Bidet Toilet Seat, White ยท 4.3 out of 5 stars 18. CDN$ 179.00 .... Maybe the sensor on the Seat is not working? I am contacting ...
Intelliseat Bidet Toilet Seat - Proper Wash
www.properwash.com > Electronic Toilet Bidet Seats
  1. Cached
  2. Similar
IntelliSeat, is one of AMDM's featured innovations bidet toilet seat, and after one use ... Toilet sensor permits operation only when skin contact is made ... Water Heater; Endless Warm Water; Heated Seat (adjustable temperature); Increased ...
AMDM IntelliSeat the Ultimate Bidet Electronic Toilet Seat - Amazon.com
https://www.amazon.com/product-reviews/B0050EJBQ0
  1. Cached
However, if you have a newer elongated toilet, the Intelliseat will probably fit just fine. ... Maybe the sensor on the Seat is not working? ..... Both seats have LED indicators for seat temperature and water temperature, but only the Intelliseat has ...
Intelliseat is a must for modern toilets - Pilot Bidet
pilotbidet.com/intelliseat-is-a-must-for-modern-toilets.html
  1. Cached
  2. Similar
IntelliSeat is one of the most advanced toilet apparatuses and after one use you ... These sensors can sense the presence or absence of a human body on the ...
=$= AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w ...
https://betojhkitchenbath.wordpress.com/.../amdm-intelliseat-the-ultimate-bidet-electro...
  1. Cached
Mar 20, 2013 - AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w/ ... Water Glow LED Faucet Light with Temperature Sensor Three Optional Colors ... intelliseat toilet temperature sensor Google Search
Dec 04, 2016 | Ovens
The seat is cracked and doesn't heat anymore, is there anything I can try before buying a new one?
if the seat is cracked then the element is probably broken at the crack site
check for circuit continuity of the element or buy a new seat
can't be too hygienic or comfortable sitting on a cracked seat
Jan 20, 2016 | AMDM Intelliseat - The Ultimate Bidet...
The remote for intelliseat doesnt work, even with brand new batteries. Any ideas?
My remote worked but the blower would not respond. If that's the issue, take the label off the remote (the corner by the heater button) and put a piece of aluminum tape over the contacts so there is a better connection. I also got a new one from AMDM (under warranty then) but I am still using the first remote I fixed. AMDM customer service: 1-800-778-1450
Feb 13, 2015 | AMDM Intelliseat - The Ultimate Bidet...
The rinse "cycle" runs for an extended period of time
not sure why this is happening...do you have the manuel to see if you can adjust the cycles or times...but it sounds like the control board may be getting stuck in cycles....try and unplug for 5 minutes then see if it goes back to normal....if not try and contact the manufacter and see what they advise...good luck
Jul 08, 2014 | AMDM Intelliseat - The Ultimate Bidet...
How to fix the remote control of my intelliseat?
A replacement control is available for $29+ dollars see attached
Jun 26, 2014 | AMDM Intelliseat - The Ultimate Bidet...
Why dose the data light keep flashing
that's normal, it means that there is data flowing. If it wasn't flashing then your router would not be working correctly.
Jun 14, 2014 | Computers & Internet
Diagnose car troubleshoot
flash?
did you check all fuse in both fuse boxes?
Jan 13, 2014 | 2006 Honda Odyssey
Why can't we get the nozzle to move?
If you need a replacement part that includes a functional nozzle, you can purchase it here http://www.ebay.com/itm/Intelliseat-AMDM-ISB-200-body-Replacement-/222019823660?hash=item33b169a82c:g:v8QAAOSwzgRWvLSS
Aug 27, 2013 | AMDM Intelliseat - The Ultimate Bidet...
Flashing
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Sep 10, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
AMDM Intelliseat - The Ultimate Bidet Electronic Toilet Seat Logo
614 people viewed this question
Top AMDM Home Experts
Tom Chichester
Duff Howell
Bill Boyd
Are you an AMDM Home Expert? Answer questions, earn points and help others
