Question about Zassenhaus 5 Kg Digital Kitchen Weighing Scale, Pink
How do i place the battery in zassenhaus digital scale
We tried a new battery but not working
Is the lithium battery placed the correct way?
Dec 28, 2015 | Conair TH402 Thinner Digital Body Fat &...
I bought a pierre cardin digital kitchen scale YHC1407C online including battery.is the battery inserted properly when u packed or should we insert it.the machine is not responding on pressing TARE...
If the scale is ''on'' then the battery is in correctly. ''Tare'' is used for making the scale read ''zero'' when a ''holder'' (such as a cup or plate) is placed on the scale and you want the scale to be at ''zero'' with that item on top of the scale. With nothing on the scale, the tare button will not do anything. Also, you have to hold down the tare button until the scale actually displays ''zero.'' (Perhaps you are just ''pressing the button'' and releasing it? You need to press and _hold_ the button down until the scale actually reads zero).
Jan 01, 2015 | Cameras
Why is The scale is not measuring anything?
Did you remove the transport protection?
Perhaps you should remove the battery and reinsert it again?
Jun 27, 2014 | Taylor 3831bl Digital Scale 6.6...
SCALE READS 20 LBS TO HEAVY HOW DO I CALEBRATE
Sounds like reset access points. Try pressing something in the hole gently to see if you can hear it clicking a switch...if it does the hold the button in and turn th scales on or turn the scales on and the press the reset. Good luck
Nov 24, 2013 | Healthometer Health o meter Glass Digital...
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
Batteries only last a couple of days
The scale has a short and needs to be replaced, if it is new, or under warranty, return it to the place of purchase.
Sep 10, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
How do I descale a Thermos?
For excessive staining use of household stain or scale remover is recommended. To remove difficult stains fill your flask with hot water, add one teaspoon of bicarbonate of soda and secure cap. Soaking overnight produces excellent results. Always rinse before re-use.
this is from http://www.thermos.co.uk/care.php
my hubby used it as he uses his thermos daily... so goodluck!
May 05, 2008 | Zassenhaus Knee Mill Hand Crank 156 Manual...
Digital scale
if scale  shows 0.000 after placing some weight on pan, it means sensor or load cell connection is open, please check sensor connection.
Mar 23, 2008 | Digi 2.5 lb x 0.0002 lb AC/DC Digital...
Zassenhaus 5 Kg Digital Kitchen Weighing Scale, Pink Logo
88 people viewed this question
Top Zassenhaus Home Experts
Donni Steen
Tom Chichester
Are you a Zassenhaus Home Expert? Answer questions, earn points and help others
