Question about Ricoh Aficio SP C240SF
Paper Tray - error - bypass tray needs paper - want to use only Tray 1
When I print from computer, it prints only one sheet and then error lite comes on saying bypass tray is out of paper
  • 1027 Answers
SOURCE: Ricoh CL3100N
Have you setup for double-sided printing?
Posted on Jul 15, 2008
  • 58 Answers
SOURCE: paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 29, 2009
SOURCE: trying to print but it ask me to load paper or form feed. also got a bypass tray message.
the problem is in the printer settings of the file you are printing, if it is set to print from bypass tray. You can load paper into the bypass tray and it will fix it. If you have a Multi Function Product (MFP) commercial grade with multiple paper sources, this message may come up again. How to fix? In the file/documents properties (word, excell. PDF,etc.) go to the File menu OF THAT document and change the "paper set up/page settiings/paer source" from bypass TO Automatic or Auto Paper. Re save the file/document and it will save your new paper source settings. If someone sends you a file, or you upgraded to a bigger machine, this message may come up and you will have to make these cahnges due to the fact that the document was created with smaller product printer/page settings. The default auto paper on business MFP's is set for a tray, not a bypass tray.
Posted on Aug 28, 2009
SOURCE: How do I print an envelope with this printer?
The bypass tray is not designed properly, when an envelope is set on the tray, the wheel is not in contact with the envelope. I just lifted the end of the envelope until the wheel could grab it and the envelope printed. So simple :)
Posted on Oct 23, 2009
TheSelkie
  • 734 Answers
SOURCE: When I try to print something it says the bypass
Take all the paper out. Turn off the printer, Wait ten minutes. Turn on the printer. Put the paper back in fastidiously.
Regards,
selk
Posted on Oct 18, 2010
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
How do i print a # 10 business envelope with the bizhub c200
First recommended that you use the bypass tray on the right side, also before placing the envelope in the bypass tray send the print job over first, the screen will say replenish paper then go ahead and place the envelope on the tray. and let it take it or hit the start button Ensure you select #10 commercial media and bypass tray in your print driver preferences. May also want to have tech come out and look at the tray and run MAX and Min. Adjustments.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 09, 2012 | Minolta bizhub 200 All-In-One Printer
Mx2300n try to print envelope from bypass tray but error says
Try putting the paper in the 2nd paper tray and then go to system settings then paper tray settings and change to paper for that drawer to envelope and maybe COM10. Then try to print on the envelopes.
Dec 11, 2011 | Sharp MX-2300N Color Copier
Can I print envelopes on my Bizhub 250
BYPASS TRAY is sed when printing onto paper with a size not loaded into a paper tray or onto thick paper, overhead projector transparencies, postcards, envelopes or label sheets Can be loaded with up to 150 sheets of plain paper, 50 overhead projector transparencies, postcards, label sheets or sheets of thick paper, or 10 envelopes referred to as the "bypass tray" throughout the manual. (See page 2-60....ATTACHED )
ftp://207.18.56.26/software/BPG/Userbizhub200250350CopyOperPh2_5.pdf
Feb 15, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
When printing it will not print from tray 2 it wants to print from tray 1 and is asking for labels. Then causing users to have to press the green check twice to change the option to print from tray 2. How...
Ok remove tray 2, and in back its got a little clicking adjustable lever that you need to move so it lines up with letter 8.5 x 11...this worked for me
Nov 27, 2009 | HP LaserJet 4700 Printer
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
No Paper Light wont go out
is this still a current issue?
Jul 22, 2008 | Brother MFC-8860DN Printer
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
Ricoh Aficio SP C240SF Logo
46 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
