Question about Dell 1200MP DLP Projector
What do I plug the projector into on the laptop
Unable to connect with the projector even though the two are connected
This is a hard question to answer because it's sort of like going to the docter and only saying "i'm sick." but i'll do my best.
First i'll assume that your using a laptop to connect to the projector, laptops work with projectors very differently to a desktop computer or DVD player for instance.
Before you turn the laptop on, make sure the cable is securly in and the screws on the cable are fastened in properly, but not too tight. Make sure of this at the projector end aswell but at this end also make sure that your going into the appropriate socket (what your plugging in to should be written just above or below it) you mainly want to make sure you have definately plugged into an input and not an output. Now fire up the projector and give it a minute to go through its usual start up process of turning on the lamp and such. Now turn on the laptop, do the same, give it a minute to sort itself out. When the laptop is done and waiting for you to use it if the image is still not sending to the projector, make sure the projector is on the correct input. almost every projector gives you the ability to plug in multiple devices. A laptop is usually plugged into 'input A' or 'PC' or 'VGA'. If you are still not getting a signal to the projector go to the laptop. Laptops (unlike desktops) have a toggle function to let you decide which monitors you want to use. This will let you toggle between using the laptop's screen only, the projector only or both. On all laptops this is done by holding the 'Fn' button and pressing the corrent F# button. Which F# it is depends on the brand of laptop. for instance if you have a Toshiba, you hold Fn and press F5, on IBM you hold Fn and press F7, HP and Compaq hold Fn and press F4. You may be able to tell by looking at the symbols on the F keys but if not consult the user manual for the laptop.
If you are still having problems try plugging the laptop into a monitor using the same process as above, if you get an image on the monitor then the problem lies with the projector, but doesn't necessarliy mean it's faulty.
Hope this helps, but like i said it's hard to fix a problem with such a vague question.
Mar 24, 2011 | Optoma ES520 DLP Projector
Tip
How to connect a laptop to a projector or external display
1)Plug in either the vga or dvi into both the projector and the laptop.
2)Plug in the power cord to the projector,then turn the projector on.
3)Once it has past its warm-up period,find the function key on your laptop.(Fn)
4)Along the F1,F2,F3 ect keys,press find the one with the picture of the display.
5)When you have found it,hold down Fn and press the display key down until it clones the laptop and projector.
on May 08, 2010 | Computers & Internet
Projector is connected to an HP laptop. Once everything is plugged in and the projector is turned on, I turned on laptop as per the manual. The projector recognizes the device, shows the HP start up...
Press Fn + F4 keys, it will change output to external monitor.
Toggle keys to get needed combonation: projector only -> Projector+Laptop screen -> Laptop screen
Mar 09, 2011 | Dell 2300MP Multimedia Projector
Connection with laptop
Jul 02, 2010 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
I have a Dell 3400MP Projector. When I plug it into my Dell Latitude D810, the screen size expands from 100% to 6400%. Not sure what is this causing this?
Hi
This is because the screen resolution on the laptop is much higher than the maximum supported by the projector. Try dropping your screen resolution on the laptop to 800 x 600 before plugging in the projector
Cheers
Dave
Jun 22, 2009 | Dell 3400MP Multimedia Projector
The projector can't find the source, which is my laptop. If it does find it, it lasts one, maybe two seconds, and then it's lost it. We've tried two different laptops, and it cannot hold the connection for...
Maybe the cable connected to the projector is bad?
If you shut down the laptop and plug the projector in on 'PC' mode, does the projector recognise the video output?
Jun 09, 2009 | Dell 2400MP DLP Projector
Can't project video from laptop connected to NEC NP100
you can plug in to a laptop if the laptop has vga out. affter plug play the film or something and give the view to projector. need to pushing special button on keyboard. which is with FN
May 30, 2009 | NEC NP100 Projector
Relisys projector will not show presentation from laptop
the signal resolution may not match on the projector.
Jan 14, 2009 | Relisys RHTP200 DLP Projector
Dell 1200MP DLP Projector Logo
16 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
