Question about ZM51STOCK CYMA ZM51 Tactical Airsoft Gun Stock
After loading mag and pulling back bolt then engaging bolt, the BB will not shoot and the only sound from the gun is a slight "puff" sound. Any ideas. We checked the spring in the mag.
How do I load the ****** Marksman 177 cal repeater
hold in right hand, depress cocking release with thumb, pull back cocking slide (takes some effort) till it locks out, push in on the lower front of barrel to rotate loading port to the up position (this won't move unless the cocking slide is pulled back), load BB in the top hole that is exposed (or a pellet in the lower hole), push loading port back down flush with barrel, push cocking slide forward. Marksman is now loaded. push safety button in so it is engaged. When in an appropriate place to shoot a target, push safety button back with your right finger (safety is off) and squeeze trigger.
Oct 17, 2014 | Optics
Loading mechinizm does not pick up a bb and load for fireing. Plenty in there; can hear them rattle.
The bolt should be magnetized to catch a bb. Some rifle have to load a magazine upside down to get the bbs lined up on the top with a small thumb switch. Then when you bring the bolt back the mag pickup on the bolt should take a bb from the top and load into the chamber.
Oct 15, 2013 | Crosman Optics
I just got my son a crosman 760 pumpmaster bb gun and we cant figure out how to shoot it. we loaded it, but for some reason it isn't shooting the bb's out
Are you pumping the gun??? Once you have bb's in the gun you have to **** it and then pump the foregrip 10 times then pull the trigger.......
Apr 24, 2011 | Sport & Outdoor - Others
SKS bolt jams with gun empty
If you have Cosmo any where it wont work . Clean it from inside the firing pin channel and trigger group , mine would also slam fire and bump fire till I got it all cleaned out
Oct 11, 2009 | SKS Rifle High-profile See-thru Scope...
The Bolt will not stay back after last shell is fired from mag.
Try putting the original magazine back in.The tapco mag probably does not have the vertical extension that holds the bolt open.Compare the two mags side by side.Good Luck
Apr 07, 2009 | SKS Rifle High-profile See-thru Scope...
Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Apr 05, 2009 | Toys
Crosman c11 clip problem
What i did was i get a screwdriver and inserted where the bbs go then push a little down so the metal would expand a little.Hope its helpful
Mar 29, 2009 | Crosman (4032)
ZM51STOCK CYMA ZM51 Tactical Airsoft Gun Stock Logo
60 people viewed this question
Top ZM51STOCK Sport & Outdoor - Others Experts
Are you a ZM51STOCK Sport and Outdoor - Other Expert? Answer questions, earn points and help others
