Question about Home
I have put 4 new solenoids on my triton as2000x but the water keeps pouring out. why does this keep happening
2 Suggested Answers
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
Hi i just installed a triton cara shower and the water wont turn off
It is probably the water solenoid valve wich is stuck or bunt out.
If it is brand new, maybe you have warranty.
May 20, 2010 | Home
How do i put water for the radiator?
Does your car have a cap or a sealed unit? You don't want a sealed unit. You want to be able to check your water.Push down and Twist the cap off when cold, not hot, fill it up with coolant, 50/50 mix, and fill up the expansion tank. It says coolant on it. The car will balance itself out. Check the water in your battery while you are at it. It dries out too. Then check the brake fluid, power steering fluid, and oil. That should keep you busy next Saturday. Hope this helps.
May 23, 2010 | 2002 Mercury Cougar
How to use coffee maker
This type of coffee maker is made to keep hot water always ready to make another pot.
Pour water in ( at least 4 cups)then turn it on with the pot installed to catch the water. It takes a few minutes to get it hot . You might hear it heating. I can with mine.OK after the heating sound goes away put some coffee in the filter and in stall the filter.Now, fill the pot again (at least 4 cups) and pour the water in and put the pot ready to catch the coffee.It makes the coffee fast because it already heated the water from the first time you poured it in.When finished with the coffee just turn off the burner only.These types are made to stay on 24 hours a day.
I just turn mine off and let it heat up the water in the morning.
Nov 04, 2009 | Bunn Pour-O-Matic VPR
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water pours into dishwashe and spills out when not running
sounds like you have a bad water valve solenoid, however their is a float switch on inside btm floor frt of dish washer that senses the level and cuts off the valve, however if the valve is bad then it will never shut off. good thing you were home. i would replace the water valve, that is located behind the front access panel . hope this helps
Sep 17, 2009 | Danby 22 in. DDW399 Free-standing...
My freezer has water that leaks into the bottom and freezes but water also leaks out onto the floor
Inside the freezer at the bottom in the back there's a drain hole that must be clogged and the water from every defrost cycle freezes up and make it worse , so first pour hot water into the drain to melt the ice and keep pouring until it goes through .Keep the drain clean doing this every 3 or 4 months.
Aug 10, 2009 | GE Refrigerators
Nothing happens when I press start button on my shower
try flushing out the water pipes put some pressure on it with the selenoid taken out and nothing but the pipe there use some shark bite fitting I know this is in close quaters and if you don't know how to solder these are easy connections, take the whole assembly out and flush it, might have a kink in one of the tubes to the shower
Apr 11, 2009 | Water Heaters
Dec 09, 2008 | Home
1999 dodge intrepid
TAKE IT TO SOME ONE ELSE!! he obviously doesnt know what he is doing. please email me at meanness628@aim.com with any other info or questions
Sep 19, 2008 | 1999 Dodge Intrepid
LG WT-R801 keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 16, 2008 | LG WM0642H Front Load
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
