Question about GE Microwave Ovens
Wattage for ge microwave jes1456wj02
Need wattage and cu ft
Illeagle
  • 525 Answers
SOURCE: Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Posted on Jun 03, 2008
  • 218 Answers
SOURCE: Need manual for Oster microwave
Try this...
http://www.curtisint.com/html/custservice/manuals/OST_OMW1199_EN.PDF
By the way, in case you ever need to search by your model number, the first digit is the letter O, not the number zero.
Posted on Nov 14, 2008
  • 686 Answers
SOURCE: F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Posted on Apr 08, 2009
localwonder
  • 6784 Answers
SOURCE: no power. outlets is fine. please help. thanx
This will occur if the inverter has experienced a surge or, if the cut off fuse has blown. you can check the cut-off fuse by removing the cover. it is located near the magnetron tube. replace it if it is blown. if the fuse is ok, this will confirm inverter failure. replace the inverter in this case.
Posted on Aug 29, 2009
SOURCE: Need replacement microwave for 6 yr. old Thermador MBBS microwave
I have the Thermador MBBS/01 in a Theramdor oven/warming drawer/microwave unit. When I was told it would be $600 to repair it, I called thermador & they don't make a replacement. Thermador CS was even rude about it. I searched & searched for a microwave that would fit & found a GE model JEB1860M1SS at Home Depot for $259.00. My husband & I just installed it & the frame kit inside, on the old Thermador micorwave fit PERFECT! I could not believe it. I thought we would either have to settle for something looking tacky in the hole or buy a whole new unit. Looks like it came in that unit.
Posted on Mar 27, 2010
Does GE make a 1650 watt microwave oven?
The highest wattage GE microwave sold to consumers seems to be 1200W. See http://www.geappliances.com/ge/microwave-oven.htm . That's the rated microwave power. The power draw from the outlet on this type of microwave is 1650W. See the Profile series 2.2 cu. ft capacity microwaves, like the PES7227DLBB, http://products.geappliances.com/appliance/gea-specs/PES7227DLBB
I hope this helps.
Apr 22, 2018 | GE Microwave Ovens
What cu ft and wattage is this model?
Input in google search the MAKE, the MODE and "specifications" and maybe you'll ge this info somewhare,
Also you can look for MANUAL
Jun 07, 2015 | Microwave Ovens
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
WHAT IS THE WATTAGE OF MODEL JVM1650WHO1 MICROWAVE OVEN
JVM1650WHO1 has 1.6 Cu. Ft. Capacity - 1000 Watts (IEC-705 test procedure)
You can rate my answer if this helped you.
Sep 27, 2011 | GE JVM1650 1000 Watts Microwave Oven
I am looking for the wattage of a ge spacemaker microwave model #JVM1640WJ03
According to the GE quick specs sheet, this is a 1000-watt oven, 1.6 cu. ft. capacity. You can also download the manual here if you need a copy.
Jan 31, 2011 | General Electric Microwave Oven
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
May 10, 2010 | Emerson MW8675W Microwave Oven
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
197 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
