Question about Philco (R) Classic Turntable CD Shelf System
I need a manual for the Philco 841-205
How can I get a manual for this unit
I need an owner's manual for Philco SDTV E175216 please and thank you
Please go to the factory support site to see if this manual is available, we do not have it here.
Jul 08, 2017 | Philco Televison & Video
On my Philco Turntable CD with cassette the CD player does not close all the way. If you manually close it, it does not play
You are describing too problems, won't close all the way, could be a bad loadind belt. the second issue it will not play, the timing gear is out of sync, or the laser pickup is not functioning, you will need to take it to a service shop for assessment.
Jun 02, 2012 | Philco (R) Classic Turntable CD Shelf...
Recently purchased a Philco dehumidifier, model PD24GE. It turns on perfectly well but the humidity reading always says 20%, even if I put it outside where I know the humidity is at least 80%. Any...
Astro9boy, when I first read your post, I considered the problem was was just operator error. But, when I read the Owners Manual for your unit, I changed my mind. It seems there may be a problem with the control panel. But, attempting to reset it may solve the problem.
Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes.
After the time has elapsed, plug the unit in and turn the Master ON/OFF Switch ON
Hopefully, during that 15 minute timeout, the unit reset itself & reverted back to the original factory settings. If so, you can set the controls where you desire.
In case you have misplaced your Owner's Manual, I have included a link to it that you can download and print for future reference. http://www.gilman-group.com/gilman_product_usermanuals/PD24GE_eng.pdf
If the above does not sole the problem, you will need to contact Philco, or the p;ace of purchase, as the unit is still under warranty.
I hope this helped you troubleshoot & solve the problem.
Jul 13, 2011 | Dehumidifiers
Need another name this could be under to program universal remote
Westinghouse don't actually make TVs, they are just 'badged'. Westinghouse is part of the Electrolux group, so the obvious answer would be another Electrolux company that DO make TVs. The only one I can find is Philco, however I happen to know that some or all Philco units are made by Funai Corp. of China. The following are all TV brands made by Funai:
Funai
Magnavox
Symphonic
Sylvania
Superscan
Element
Philco
Durabrand
Trutech
Emerson
ESA
Try Philco codes first (if there are any) then work through the above list. It's likely that your TV is made by Funai and has the same components as one of the above brands. Please note that not all universal remotes will work with all TVs and universal remotes often don't work when the TV is newer than the remote.
Hope this helps!
Regards,
BElectric
Nov 18, 2010 | Westinghouse LTV-19w6 Television
The turntable on my philco cd cassette and turntable unit does not turn. how to i access the belt, etc. to see whats wrong?
I had a similar issue with my Crosley turntable that I recently picked up... and after digging up the manual online all I had to do was lift up on the tone arm and move it to the right (past the holding mechanism) until it clicked, and voila, the turntable started spinning again.
I hope this helps!
Sep 18, 2010 | Philco (R) Classic Turntable CD Shelf...
Need code for ufc4220 to Philco
I am not certain that this Big Easy universal remote will control dvd players; there aren't any listed in the users manual.
Please find the users manual for your URC-2585 Big Easy here. I recommend searching for a compatible code by following these instructions.
I hope that helps.
Jan 19, 2010 | Philco (R) Bakelux 10245 CD Shelf System
Need a coloured wiring diagram for a Philco washing machine Model WM1062
Check for your service manual inside the control panel - or inside the shell of the unit. Every unit sold is included with one.
Inside the service manual are all the schematics you need.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 16, 2009 | Washing Machines
Power supply
This unit takes a 12V 0.5A DC power supply. Your local Radio Shack sells this type of supply that will plug into the wall. You'll need to make sure that the other end will plug into the turntable, but for the supply, Radio Shack is probably the quickest way.
Jul 24, 2008 | Philco PC-841.651 Turntable
Where can I get another remote?
Your gonna need a model # man. If http://www.remotes.com dosent have one, Look in the owners manual for an addy and contact the company there. Good Luck
Aug 06, 2006 | Philco (R) Classic Turntable CD Shelf...
Philco (R) Classic Turntable CD Shelf System Logo
41 people viewed this question
Top Philco Audio Players & Recorders Experts
OSU_Matthew
Level 1 Expert
 Grubhead
Grubhead
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
