Question about Home
Toto cst964cf what is the name of this model of toto
KU990 .pxo file problem
hay there ..it will help you...i just made that same mistake but i overcome from it..connect ur mobile to usb..and open it through efs media..then.select the port if it shows..if not try refresing and reconnecting...after connect u will see a new lg app create by system..rename it to toto again and disconnect ..then reconect and rename..toto to lgapp..this return back my viewty..and am so glad..
Nov 26, 2009 | LG KU990 Viewty
Flush handle stays in up position when flushing my Toto MS974224CF(G) Guinevere toilet. My other Toto, same model, works fine. I have tried changing the flush handle and changing the length of the chain...
Sorry, didn't read the whole thing. Moving parts do get sticky. Try cleaning, maybe with a soft wire brush if necessary, any of the turning parts involved. And a little WD-40 or migrating fine oil spray by any other name will do. Otherwise, a small bend introduced to one of the arms involved may help. It would be best if you could watch the operation, and if you can slow or speed the water coming in, that might change the performance. See if that helps.
Jul 02, 2009 | Totoku CCL250i Monitor
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
HOW TO FIX YELLOW REFRESHING SCREEN AS MY LOCAL MOBILE PHONE SHOP HAS FAILED TO BE ABLE TO RE FLASH THE FIRM WARE PLEASE HELP
a2ee4a7.gif LG_Authority
conect your phone with the usb port.
start in windows the program EFS MEDIA BUILDER by AKOM1976.
select connecton and after that you choose efs explorer select connection.
Now you see the files on your phone
maye there is a folder named as TOTO
be sure that this folder is on your phone!!!
If it does delete the folder named as LGAPP
after that rename the folder named TOTO to LGAPP
richt click and choose refresh.
now exit the efs program.
Turn your phone off and then after a few seconds on
the phone will startup normaly as always and its normal asual.
I hope this will work or you have to back up with the LGMDP euro
an after that choose restore and choose the image file *.nv2
This will work!
you can try a software update at http://nl.lgmobile.com/web/web.product.manualSoftwareRF.laf
This software update is at your own risk.
Choose your model of your mobile phone and download it.
Fallow the instructions by the software update be patience
if you don't see anything it take a few moments.
Comment posted on May 04, 2009 No you have to see that the folder already exist on your phone
LGAPP and a nother folder TOTO if the phone starts up and you didn't switch the folder it make a new folder LGAPP without the programs so all the folders in the folder LGAPP are emty.
So thats why you have to be sure that the folder TOTO is already exist on your phone.
And if you have a backup of the folder TOTO you can check if the maps are empty or not.
These files have to be in the map toto on your pc.
These are the file names that is logged by EFS explorer, you can see the folder names and the files that are in the folder map exist
Check if these file are located in the folders of your phone if not
delete the emty folder LGAPP and make a new folder named TOTO open that folder.
Now read the files that is on your pc in the map TOTO.
This folder have to be the files in it and doesn't suppose to be empty.
The files you need to see on your phone with EFS explorer looks like this:
LGAPP
LGAPPCommon
LGAPPDRM
LGAPPDRMCERT
LGAPPDRMCERTCERT
LGAPPDRMCERTCERTdevelopcert.cer
LGAPPDRMCERTCERTdevicecacert.cer
LGAPPDRMCERTCERTdevicecert.cer
LGAPPDRMCERTCERTdevicepkey.cer
LGAPPDRMCERTCERT ootcert.cer
LGAPPDRMCERTcmla
LGAPPDRMCERTcmladevicecacert.cer
LGAPPDRMCERTcmladevicecert.cer
LGAPPDRMCERTcmladevicepkey.cer
LGAPPDRMCERTcmla ootcert.cer
LGAPPDRMDPRO
LGAPPDRMDRMCERTTYPE.TXT
LGAPPDRMID
LGAPPDRMIDSYS
LGAPPDRMISAMDB
LGAPPDRMISAMDBCertDB.bin
LGAPPDRMISAMDBCertDBKey_CTYPE.bin
Etc.
[ File Renamed ] LGAPP->TOTO
These files are on the pc:
TOTO
TOTOCommon
TOTODRM
TOTODRMCERT
TOTODRMCERTCERT
TOTODRMCERTCERTdevelopcert.cer
TOTODRMCERTCERTdevicecacert.cer
TOTODRMCERTCERTdevicecert.cer
TOTODRMCERTCERTdevicepkey.cer
TOTODRMCERTCERT ootcert.cer
TOTODRMCERTcmla
TOTODRMCERTcmladevicecacert.cer
TOTODRMCERTcmladevicecert.cer
TOTODRMCERTcmladevicepkey.cer
TOTODRMCERTcmla ootcert.cer
TOTODRMDPRO
TOTODRMDRMCERTTYPE.TXT
TOTODRMID
TOTODRMIDSYS
TOTODRMISAMDB
TOTODRMISAMDBCertDB.bin
TOTODRMISAMDBCertDBKey_CTYPE.bin
TOTODRMISAMDBDCtxDB.bin
TOTODRMISAMDBDCtxDBKey_DID.bin
Etc.
and its fine to have these as my back up.
If your folder LGAPP on the fone is emty don't worry write the files from your pc to the phone Make a folder named TOTO.
and write all the files include the foleders in to TOTO at your phone.
When you fineshed. Rename LGAPP >> XLGAPP
Rename TOTO >> LGAPP.
Delete the folder XLGAPP.
Refresh and disconnect and you will see the phone startsup in
a normal mode. As you can see I delete th folder LGAPP that was empty.4f0b046.png
Now I read the folder that is back it up on my pc to the phone.
Now when its finished I renane that folder to LGAPP.
When yo finished diconnect the phone by clicking disconnect.
So the phone start automatical again and now its running in norma
mode asual. I hope this will work for you.
May 06, 2009 | LG KU990 Viewty
My lg ku990 has yellow sreen
iyourfatherl
maybe this will work.
This will work!
Mar 14, 2009 | LG KU990 Viewty
Toto GMax Flushing System drips
What you are experiencing is a flapper valve problem. Since I don't know what model you have I will give you a link to the generic GMax unit. Here is the parts breakdown for a GMax
Toto GMax
I would suspect you need part #7 on this diagram a flapper valve. Take the old one with you since different colors ones are used on different models. You should go to the Toto site to locate a dealer first. You can find their site here:
Toto USA
Hope this helps and please remember to rate this!
Dec 07, 2008 | Toto Home
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
