Question about Ricoh Aficio Mp161 Copier Photocopier Copy Machine System Mp 161 Ricoh
Block fax number
Can you block a fax number to stop unwanted faxes
2 Suggested Answers
  • 1218 Answers
SOURCE: does this fax machine have the capability to fax a
Sure...its called "broadcasting"...check you users manual on how to.
Posted on Feb 19, 2011
How do I block unwanted faxes on my Sharp MX-4111N Printer?
There should be a section in the manual. Not to sound text bookish and evasive but each is a little different But a fax is a fax. it's a land line that still has parameters. To block an in coming fax would be the same as a blocked call on your house phone. Some mild programming knowledge would be required. Just as if I would say mild know-how to program a remote or change a contact on your e-mail list. If these last items are a challenge for you then entering data in a fax may not be your ball of wax. someone you know might help out. If you're up for the challenge then I would have you pull out the book on the fax portion of your printer. Nice multi-units like that usually have 2 or 3 books, each having to do with a major function. ie fax//printer// networking(connecting to a hub). The fax book will have sections on entering speed dials and group polling and this is the area that will detail what buttons to push. some even have a length of fax to dis-allow long drawn out junk mail. Some businesses control their unwanted faxes by setting up just the opposite~~numbers ONLY to accept. Others no matter what get ignored. Another way if these don't work is what many businesses do is to put a time to receive, which basically is arbitrarily 7am to 430pm. You might just eliminate a lot of unwanteds that way.( knowing specifically that they always call after 7pm... or such...get it? ) good luck hope this helps a smidge~~~SC
Oct 17, 2014 | Sharp MX-4111N Copier w/ 36 Month Warranty
Can I block junk faxes on a DP80F Fax
I suggest a informative links please visit and read it.
Block Unwanted Junk Fax Numbers and HP Printer Support
Thanks,
Sep 10, 2014 | Toshiba DP80F Printer
Brother Intellifax 2820
most new machines have a fax block mode to eliminat unwanted faxes coming through, just reset your fax machine to factory setings and then re load your personal data , this should rectify this problem
Apr 12, 2010 | Brother IntelliFax-2820 Laser Fax
How can i block a junk fax number in a hp j3640 thanks in advance
Set the junk fax mode
By default, Block Junk Fax mode is turned On . If you do not subscribe to a caller ID service through your phone provider, or do not want to use this feature, you can turn off this setting.
To set the junk fax mode
Press Setup .
Press the right arrow to select Basic Fax Setup , and then press OK .
Press the right arrow to select Junk Fax Blocker Set Up .
Press the right arrow to select Block Junk Fax the press OK .
When prompted, press 1 for Yes or 2 for No .
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from your caller ID history, or you can enter new numbers. The numbers in your junk list will be blocked if Block Junk Fax mode is set to On .
To select a number from the caller ID list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK .
Press the right arrow to select Add Number to Junk List , and then press the right arrow to select Number and then press OK .
Press the right arrow to scroll through the numbers from which you have received faxes. When the number you want to block appears, press OK to select it.
When the Select Another? prompt displays, do one of the following:
If you want to add another number to the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you are done , press 2 to select No .
To manually enter a number to block
Press Setup .
Press the right arrow to select Basic Fax Setup press OK .
Then press the right arrow to select Junk Fax Blocker Set Up and then press OK .
Press the right arrow to select Add Number to Junk List press OK , and then press the right arrow to select Enter Number .
Use the keypad to enter a fax number to block and then press OK . Make sure you enter the fax number as it appears on the display, and not the fax number that appears on the fax header of the received fax, as these numbers can be different.
When the Enter Another? prompt displays, do one of the following:
Remove numbers from the junk fax list
If you no longer want to block a fax number that number can be removed from the junk fax list.
To remove numbers from the junk fax list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK , and then press the right arrow again to select Junk Fax Blocker Set Up then press OK .
Press the right arrow to select Remove Number from Junk List .
Press the right arrow to scroll through the blocked numbers. When the number you want to remove displays, press OK to select it.
When the Delete Another? prompt displays, do one of the following:
If you want to remove another number from the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you subscribe to a caller ID service through your phone provider, you can block specific fax numbers, so the HP Fax does not print faxes received from those numbers in the future. When an incoming fax call is received, the HP Fax compares the number to the list of junk fax numbers you set up to determine if the call should be blocked. If the number matches a number in the blocked fax numbers list, the fax is not printed. (The maximum number of fax numbers you can block varies by model.)
Thank you.
Sep 17, 2009 | HP J3680 Officejet All In One Printer
Panafax 585 block fax reception?
Press
Function
64
set
look at your settings again
Fax number 1 set to tel
Fax number 2 set to fax / tel
Feb 18, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
BLOCKED CALLS
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
off this setting.
▲ Some models have a Block Junk Fax button. Depending on the model you have,
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Have Lexmark X9350 All in one - Need to block incoming junk faxes
You can find these instructions on page 140 of the User's Guide. The English User's Guide is here: http://images.lexmark.com/publications/pdfs/2007/9300/v1116690_en.pdf
If you have Caller ID, you can block faxes sent from specific numbers and/or all faxes which do not include a Caller ID number.
To turn on the Block List feature:
  1. From the control panel, press up arrow or down arrow repeatedly until Fax is highlighted.
  2. Press select (checkmark).
  3. Press up arrow or down arrow repeatedly until the Fax Setup submenu is highlighted.
  4. Press select (checkmark).
  5. Press up arrow or down arrow repeatedly until the Fax Blocking submenu is highlighted.
  6. Press select (checkmark).
  7. Press up arrow or down arrow repeatedly until you reach the Block List menu item.
  8. Press left arrow or right arrow repeatedly until On appears.
  9. Press left curved arrow to save and exit.
To add each fax number you want to block:
  7. Press up arrow or down arrow repeatedly until you reach Blocked Fax Add Entry.
  8. Press select (checkmark).
  9. Use the keypad numbers to enter the name of the person associated with the fax number in the Name field.
  10. Press down arrow once.
  11. Use the keypad numbers to enter the fax number in the Fax Number field.
  12. Press left curved arrow to save and exit.
To block faxes sent from an unidentified number (a number with no Caller ID):
  7. Press up arrow or down arrow repeatedly until you reach the Block No-ID menu item.
  8. Press up left arrow or right arrow repeatedly until On appears.
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Ricoh Aficio Mp161 Copier Photocopier Copy Machine System Mp 161 Ricoh Logo
44 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
