Question about Beldray Handheld Steam Cleaner, 1000 Watt, Purple
No steam from beldray steam cleaner
Filled water tank as instructions, then flashing light at water tank appears,retried and got blue water tank lights, pressed button 2 as instructed but do not get any steam.
I have got beldray. Steam mop not a vauuum I put water in switch it on red lights come on then go blue I will turn on steam and it will just not steam.
Lord Blake there sounds like there is a problem with the trigger or the seals for the steam pipe. Check it over completely and make sure it's assembled right.
Nov 02, 2014 | Vacuums
My beldray steamer water won't heat or steam red light on then blue nothing happens where am I going wrong
Steam outlet could be calcified, (need cleaning) happens if you don't use purified water.
Sep 30, 2014 | Cars & Trucks
Why does my Beldray steam mop leave floors so wet
It probably has mineral deposits inside from the water. This build up of mineral deposits prevents the water from heating up to a high enough temperature. So instead of hot steam, you get hot water.
Jun 03, 2014 | Beldray Handheld Steam Cleaner, 1000 Watt,...
Cannot open water tank for beldray 5 in 1 steam cleaner
Its very hard to open the tank as it has a seal on to stop water and steam escaping hold it tight and twist anti clockwise
Nov 09, 2013 | Beldray Heating & Cooling
What to do when blue light is on and water wont come out the steam penguin
Blue light comes on top of penguin gets hot but the water tank stays cold no steam
Oct 28, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
Require instructions/manual for Beldray 2 in one steam mop
I WAS AFTER THE WEB SITE FOR BELDRAY AS I NEED MOP CLOTHS BUT CAN NOT FIND THEM SOLD ANYWHERE . I COULD NOT EVEN GET THE 2 IN ONE TO WORK BUT FINALLY DID BY REMOUVING THE PIPE WITHIN THE WATER BOTTLE WITH THE BALL VALVE ON THE END AND THEN IT WORKS A TREAT WHEN USED AS A FLOOR MOP AT LEAST . I MAY HAVE TO REFIT THE PIPE AND BALL VALVE WHEN I NEED TO USE IT AS A HAND DEVICE I HAVE THE MANUAL THAT CAME WITH THE 2 IN ONE BUT THAT'S NOT A TECHNICAL MANUAL IF THAT IS ANY HELP
Apr 10, 2012 | Vacuums
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
My sirena does not work
anytime the water runs out and you need to refill the tank, you need to bleed the line so to speak. Take an empty cup and put it under the wand and open the knob of the steam wand until the blue light stops flashing
Feb 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Beldray Handheld Steam Cleaner, 1000 Watt, Purple Logo
32 people viewed this question
Top Beldray Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Beldray Heating and Cooling Expert? Answer questions, earn points and help others
