Question about JVC HX-C6 Shelf System
PROTECT COMES ON - JVC HX-C6 Shelf System
Kenwood a76 protect mode
hi, if protect comes up while the amp is standing alone without any speaker leads or input leads connected, then you definitely have an internal circuit fault, with either the power regulator circuits, or the amplfier circuits.
Jun 07, 2012 | Car Audio & Video
Its on protect mode how do i take it off?
Generally if your amplifier goes into protect, you have a bad ground.
Unhook your power wire from the battery and trace your ground wire to the chassis of the vehicle. Strip the paint from the ground location, Put the ground wire back on the grounding location. Tighten the ground wire down securely with no play and hook back up your power wire.
Other cases revolve around the RCA cables.
Unplug the RCA's and see if the protect light goes off.
Plug one in and see if the protect light comes on and then the other.
If the protect light comes on, you have bad patch cables. Replace them and see if your issue is resolved.
If the amplifier was shorted, the system board made have been damaged.
Jul 28, 2010 | Car Audio & Video
Protect
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Send to Rockford Fosgate for repair .A thumbs up would be greatly appreciated if this answer is helpful to you. protect-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 29, 2010 | Rockford Fosgate Power 1001BD Car Audio...
The 12 volt connection sparks when connected. then not even the protect light comes on. the protect light only comes on when the remote wire is connected and the power wire is not.
The 12 Volts being applied will spark initially. There are large capacitors on the input powers supply rail. Once they charge no more spark. The protect light comes on when you apply remote voltage because you are actually telling the amp to turn on and there is a problem with it like an output transistor is shorted or your power supply could have a problem. Hope this helps.
Dec 05, 2009 | Koiiler XM-8787C Car Audio Amplifier
Protect light keeps coming on when i give my jensen amp power
Eith some wires touched, you dont have big enough fues or you have somehting hooked up wrong
May 28, 2009 | Jensen LXA300 Car Audio Amplifier
Power Protect still comes on now and again
Amplifier output chip in stereo is defective and unit gives error message of push power protect.
You need to replace output amplifier IC and check supplied voltages.
Feb 28, 2009 | Sony MHC-RXD5 Shelf System
Display says protect
check your low voltage fuses, the protect light up when a overload comes....
Jan 28, 2009 | Audio Players & Recorders
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
JVC HX-C6 Shelf System Logo
27 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
