Question about Dishwashers
Getting an error code FE in Lg direct drive dishwasher
  • 3 Answers
SOURCE: LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
Posted on Nov 07, 2010
chargerhp
  • 813 Answers
SOURCE: LG Dishwasher LD-2050WH with HE error code
LG Told me the water coming in was to hot and to disconnect power for a few seconds and reset water heater to around 120 deg
Posted on Jan 31, 2010
rylee_smith
  • 8619 Answers
SOURCE: My LG Dishwasher model LDF7811WW was getting
Hi
Thanks for using FixYa. Error FE in your Dishwasher indicates excessive water is supplied than the normal water level. If the dishwasher is overfilling it's
caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 28, 2010
  • 500 Answers
SOURCE: getting an error code OE
Hi Ged Lunny,
The OE error code means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks.
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
Posted on Jun 09, 2011
  • 70 Answers
SOURCE: My LG direct drive dishwasher
Hi, according to the owner's manual on mine, "IE ERROR" means it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine. Once you unclog the water hose, you error code will disappear.
Posted on Jun 21, 2011
Getting FE error saw a answer for this model on fixya said to clean the float module where no plastic float on bottom of washer
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced. If the error persists even after the water inlet valve has been replaced there may be a problem with the main control circuit board
Oct 25, 2015 | LG LDS5540 Semi-Integrated Dishwasher with...
Lg dishwasher fe error code
This is a fill error, check your tap is on and that the inline filter screen is clear, if all is good then you have an inlet solenoid issue.
Mar 05, 2012 | LG Dishwashers
When the wash cycle is going it starts to make a tune and then FE starts flashing I need to know what FE means
Hi there Celina the code FE has a few differant meanings depending on the dishwasher model. If you can provide me with the model code I can help you with this problem.
Nov 21, 2011 | LG Dishwashers
My LG direct drive dishwasher is giving me an IE or 13 error
Jun 21, 2011 | LG Dishwashers
Getting an error code OE in LG inverter direct drive dishwasher and water not draining
Hi Ged Lunny,
Kind Regards :-)
Jun 09, 2011 | Dishwashers
Dishwasher won't run much of the cycle.
LG dishwasher 2009 lds4821bb, water does not heat up anymore. thanks
Jan 26, 2010 | LG Dishwashers
AE displayed on LG dishwasher
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Hi there I have a silver LG dishwasher..I am intermittentleey getting the Code PE. I have take the pump off the exit water pipe and chaeck for blockages etc... there are none. Any ideas?
Please confirm the model number of this LG diswasher.
On recent LG units, the avaiable error codes are: IE OE E1 FE tE LE
The PE code is abnormal. Can you confirm.
I would expect to see the error OE if water is not fully pumped out. Remove the filter from the sump area beneath the bottom rack. Look closely for debris causing a blockage/lock. Please get back to me with your findings and ask more questions as needed.
Jan 25, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
419 people viewed this question
Top Dishwashers Experts
